What psi can u push the ca18det to b4 she blows
From Newcastle
just wondering what psi could you pump into a stock internal ca b4 doing internals?
Posted on: 2007/6/24 13:39
Re: What psi can u push the ca18det to b4 she blows
From Mudgee NSW Australia
How long is a piece of string??
It depends on many things. How good the tune is what condition the engine is ect ect.
I would say with a good condition stock engine and tune 15psi should be fine anymore the stocko pistons will probably fail might last for a little while with more boost but again it really is the luck of the draw.
Posted on: 2007/6/24 22:36
If In doubt run more BOOST
From perth airport
most tune shops will say 1 bar but i hear a lot of backyard drifters say 12 psi or 14 psi is ok
Posted on: 2007/6/24 23:03
would this be with a stock turbo or upgraded? just out of curiosity.
Posted on: 2007/6/24 23:19
From Vic Bendigo
lol why not put a a12 in it and run 20psi with stock internals lol its been done evan more up to 30psi on this site
Posted on: 2007/6/24 23:24
From Newcastle
lol does it matter what turbo just asking what pound lol but its a hiflowed t3
Posted on: 2007/6/24 23:48
From perth airport
when you go a bigger turbo the psi is how you say stronger ? or something
Posted on: 2007/6/24 23:59
The word you are probably looking for is efficient. This is true, it does depend on the turbo not just the reading on your boost guage.
To attempt to run 14psi with the stock turbo to redline would be pushing the compressor right out of it's efficiency range. This means you get increases in inlet air temps and less power compared to a larger turbo pumping that much pressure at a cooler temperature.
Posted on: 2007/6/25 0:14
From Newcastle
thanks boys any more info . . . . ? just want to know as much as i can
Posted on: 2007/6/25 0:55
From SE Melbourne
I think there are a bunch of good technical articles on turbocharging at the Garrett website that could help yoy in knowing as much as you can.
I remember ca18det_man pointing them out when he bought his new turbo.
Posted on: 2007/6/25 0:59
Mildman, Datsunless
(1) 2 3 »
