Anyone had this happen?
From brisbane
I started my car up yesterday after completeing three problem free sessions at QR only to find that the oil filter had nearly spun off and the contents of my sump were now on the ground under the car!
I couldn't believe it. I was very lucky as someone standing in front of my car yelled a warning to me and I shut it down straight away.
The filter has been on there for over a 1000kms and all of a sudden it worked loose.
Anyone had this happen to them?
Matty
Posted on: 2007/9/16 13:05
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: Anyone had this happen?
I've heard of this happening on a-series motors, never on a CA. How tight do you put them on?
Posted on: 2007/9/16 13:06
From brisbane
Pretty bloody tight. I always do them up as tight as I can by hand.
Posted on: 2007/9/16 13:29
go a big hose clamp around it once ts installed and wire it back to the engine mount ... put the clamp on and then wire it in the direction that'll stop it turning anti clockwise loosening itself ... got to make sure it's wired to someting that moves/vibrates with the engine preferably ..
Posted on: 2007/9/16 13:39
From Townsville, Qld
hmm, I've never heard about that happening before but now I'll have to be mindful of it
Posted on: 2007/9/16 14:14
From Stirling, South Australia
My escort used to do this all the time! It has only happened once on my 1000 wagon but it was only a little leak needing a quick tighten. The contraction and relaxation of the metal as it heats up and cools down is often enough to work thing loose let alone vibrations too! hence you should always tighten you exhaust manifold/flange nuts after 100km's and again at 1000km's.
Posted on: 2007/9/23 9:17
LIFE'S TOO SHORT TO DRINK INSTANT COFFEE!
