Browsing this Thread:
1 Anonymous Users
1200 ute Diff Housing, what fits in? |
From Wallan, Vic, Aus
Hey guys, I have a 1200 ute diff in my 120y and it has packed in, or is about to, make a ding ding noise as i drive down the street. Put in on stands and had the car going in 3 rd to get a bit of speed and im pretty sure the sound is coming from inside the diff housing. So my question is, what diff centres will fit a 1200 ute diff housing and axles. I have a couple of 120y BW diff centres, maybe I can out that in? In case Pigdog reads this, remeber the ute diff I bought off you and you warned that one of the barings was leaking Oil? Do you think that its just baring noise?
Posted on: 2007/10/29 8:59
Re: 1200 ute Diff Housing, what fits in? |
From Adelaide, Australia
Jap assembled Stanzas and some bluebirds not sure which ones though. Someone was also trying C20 Vans if I remember right.
Posted on: 2007/10/29 9:15
cheap + fast = disaster fast + reliable = expensive cheap + reliable = stock IPRA Build
From Canberra
a12 vans should have a 4.875 centre that will fit. s1 and s2 bluebirds would probably be the most common source for 3.9.
Posted on: 2007/10/29 9:25
From Geelong, Vic
what happened to the other centre i gave you? that noise is probably just some of the welds on the centre coming off and mixing witht he bearings.....nothing to worry about
Posted on: 2007/10/30 11:22
From nowra nsw
i know wat u mean its like a chunk chunk noise lol the diff gears are probly broken ill post a pic up of my gears
Posted on: 2007/10/30 11:32
well i have conducted repairs and found that continual burn outs will cause death to a diff. I took it out and there is a small bar that goes between the spider gears, it has broken and was making the noise. As to you other diff Pigdog, I took it to work and re weld it, and have put it under the car this arvo and is as good as new. Good thing I got two centres off you, cos now the non welded one needs to be welded. I also have an a12 vanette centre, the 4. whatever, so at least i know that fits. Wouldnt that one be stronger that a 1200 ute diff?
Posted on: 2007/10/30 11:39
From Geelong, Vic
just take the pin out of one of the other centres and put it threw the one i made...and that centre i made wont actually die in a hurry but make sure you put some welds around that pin as the holes are probably now a bit bigger than they are supposed to be
Posted on: 2007/10/30 11:47
