Removing welsh plugs?
Quite a regular
From WAGGA WAGGA, RIVERINA, NSW, AUSTRALIA
Hi there i am rebuilding an A15 i am stripping the engine for an acid bath i have got all the welsh plugs out apart from the one at the back of the head it has a big hole in it now so i am stuck What should i do from here
Posted on: 2008/1/10 6:15
Re: Removing welsh plugs?
From Brisvegas, oz
what about using one of those anchor metal wall plugs that spring open that would give you somthing to pull on atleast
Posted on: 2008/1/10 6:19
www.camerasplus.com.au
Quite a regular
yer tried that mine arent big enough
Posted on: 2008/1/10 6:21
From Sydney (Carlingford)
Just done this one myself so I know your pain.
The welch plug hole in the back of the head is a little different from the others, as the hole is not the same diameter all the way through and has about a 3mm lip on the back.
This stops you removing the welch plug as you normally would.
You will just have to persevere, but be careful not to damage the alloy head.
I ended up getting vice grips on the welch plug through the whole I created and the levered off a block of wood.
Good luck
Posted on: 2008/1/10 6:34
From Sydney
die grind it a bit on opposite sides so its thin and weak then crack it in half with a quick sharp blow from a chisle...might work..
Posted on: 2008/1/10 6:51
From Newcastle
coulnt u put a slide hammer in the hole and bump it out?
Posted on: 2008/1/10 7:11
From Bendigo, Victoria, Australia.
you could try tap a big thread through the welsh plug, put a long bolt in it and pull on the bolt with vice grips.
other wise, the sharp chisel idea sounds good.
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From Burbank, CA
a good piece of wood and a hammer?
At least you have easy access to work on it.
Posted on: 2008/1/10 7:13
|||\ 81 KPB310 /|||
