ca18det wiring issues
From perth
hi guys
ive got a manual for s13 ca det (its in english and i suspect its for europe) but the boost control solenoid is not mentioned or the butterfly valve stuff.
i have 2 harnesses (1 NA man and 1 turbo auto) and cant find the connector for the prcvs.
Q1: does anyone have a jdm shop manual or wiring diagram or a link to one
Q2: do they run both prcvs and boost control on jdm
Q3: what pulse is the ecu looking for from the speedo? , can i just run speed sensor direct to ecu or does speedo process signal
a lot of the wire colors and positions are not as per manual
also need an ECU if anyone has one
dazza
Posted on: 2008/9/21 11:54
Re: ca18det wiring issues
From hastings,vic
there was a wiring diagram on this site but link wont work,do google search. Tommo
Posted on: 2008/9/21 13:19
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From SE Melbourne
This ought to help with secondary butterfly, and boost solenoid vacuum piping.
Posted on: 2008/9/21 14:40
Mildman, Datsunless
From Mandurah, Western Australia
Dazza, have got the info you need but it's with the car in my workshop. Butterfy valve solenoid are brown and grey wires. On is on power and the other is from ecu. Cant recall which one is what without checking my notes.
Also have europe manual and it is a bit of a pain.
Perth Ute (Jordy) mentioned 6 months ago he had a spare ecu???
Posted on: 2008/9/21 15:47
As for speedo let me know if you find out before me. Hopefully I will resolve this soon as currently my ecu has no speed sensor input.
Posted on: 2008/9/21 15:49
From Radelaide, South Australia
I have a stock ca turbo manual ecu free mate.
pm me if ya interested,
Dane..
Posted on: 2008/9/21 17:29
Boost.. boost.. BOOST!!! Gotta love Lag...
* 76 coupe, twin 40mm a12, project...
* 79 ute ca18det, track/street...
* 84 FJ45 landcruiser project...
* 88 D21 navara 4x4, sr20de vvt daily...
From Adelaide
are u people using electric speedo's??
coz i just used the stock speedo line into the side of the gearbox
Posted on: 2008/9/22 4:01
From perth airport
crzy1200 ute wat box u running? has the s13 box isnt cable drive , or you running the stumpy ?
im happy to say dazza took every last bit of my ca18det colection
Posted on: 2008/9/22 4:14
perth airport parking
Datsun 1200 ute A14
From Adelaide
oh yeh im using a stumpy, but even the s13 geabox i took off my ca had speedo drive,
and my mate has a sr20 black top in his bluebird wagon and all he did was take out the electric speedo and pulled bluebird gearbox speedo and put it in the sr20 gearbox and it works fine,
Posted on: 2008/9/22 6:19
From perth
thanks everybody
thanks mildman ive seen that drawing.
ive gutted the butterflys out of the intake and welded the holes up so no probs there.
the prob with the vehicle speed sensor is when you are rolling to a stop with throttle shut motor can cut out or idle badly. want to prevent problem before it starts.
yeah jordy gives everything away or bins it before checking with me! bloody kids eh!
another question, do all turbos have injector dropping resistors and can you just use high impedance injectors instead?
spent 3 hours w/ multimeter on sun (in addition to 3-4 hours last week) and just about have this wiring by the balls
dazza
Posted on: 2008/9/22 11:33
