vanette discs on datsun 1000 now with more pics!
From Darwin NT
hey guys i have almost completed my vanette front end conversion it is an absolute pig to fit in but it can be done will post up pics asap ounce i get my bits back from the engineering workshop
Posted on: 2008/9/25 8:15
current project 4x4 patrol...
Re: vanette discs on datsun 1000
From sydney
Cant wait to see it.
Posted on: 2008/9/25 10:29
From Darwin NT
heres a bit of info
the lower ball joint is a press fit type so i have had to make a 10mm plate that the ball joint presses into then i have to weld it onto the lower control arm
the upper is a bolt on type and the large hole in the top has to be enlarged and the previous bolt holes welded up then re-drilled to suit the bolt pattern of the balljoint ounce i have all this done i can then bolt it onto a parts car and see how the geometry is and if there is any scrubbing/locking
i will be taking pics as i put it together and what not
Posted on: 2008/9/25 12:28
From Newcastle (NSW)
This is interesting!
I'd be really interested to see a side by side comparison of the vanette to 1000 stub axle/upright/hub carriers/whatever you wanna call it. I'm interested to know if putting a vanette stub axle into a 1000 will lower the car or change the camber.
I'll be following this thread!
Posted on: 2008/9/26 7:44
Racecar spelled backwards is racecar!
From newcastle, NSW
very interesting indeed, i was looking at to starting to do this very soon, i'll wait for the pics and details, have you completed the set-up? how well does it stop?
Posted on: 2008/9/26 10:23
Very good thread will keep my eyes glued open for your input.
Posted on: 2008/9/27 0:40
piccy piccy now now dammit.
Posted on: 2008/9/27 3:07
Re: vanette discs on datsun 1000 with pics now!
From Darwin NT
ok guys progress piccy time
got the LCA done and am waiting on the uppers also ran into another issue i thought the 1600 tie rod would thread on no issues but it needs a larger diameter so more custom parts....
heres pics
i had the adaptor plate so it would bolt on and allow me to get it in the right position then weld it up i then filled the holes up with weld for further strength
Posted on: 2008/9/28 6:12
From Darwin NT
ok i just put it on the front of the new wagon fairly dodgy just usd the original upper ball joint and tie rod put it back on the ground doesnt make any noticeable camber changes doesnt seem to foul anywhere on anything will post up pics of the complete setup when its done with the proper parts
Posted on: 2008/9/28 9:15
From Geelong, Vic
no noticable camber changes, now wheres the fun in that
Posted on: 2008/9/28 11:38
(1) 2 3 »
