I am having a shed cleanout and have some things to get rid of
So heres abit of a list
Don't be shy to ask for other stuff you might be suprised what I have
1. SC14 Toyota supercharger.
Just the unit with the pulley on the front. No brackets , mounts , manifold etc to fit A series. I never tried to make it fit after buying it from Lobster here in 2003
$200
2. T25G turbo off S13 SR20 Silvia
Good second hand unit. No shaft play or history of smoke
$200
3. Twin weber manifold suit oval port A series. GX cast in it. I believe these were made by or for JTS.
$200
4. 1200/120Y A series 4 speed gearboxes.
$100 each x 2
5. CA18ET SOHC turbo motor from S12 SIlvia import
Comes with 5 speed box and computer , loom etc. These use a T2 style Air Research Turbo. Also have CA20 inlet manifold that goes with it to put the TB at the front to allow intercooler use. I was told when I bought it that it had 42000 km on it
Never turned over or tried to start since I got it
$700
CA18ET6. 1000 upper ball joints new. 1 pair available. Aftermarket units
Last time I bought some in about 97 from Nissan Genuine cause I couldn't get aftermarket they were about $125 each
$100 pair.
7. Chrome KB10 tail light surround. Unsure what side or even if they are different left to right.Brand NOS in Nissan box.
$50
8. Pair of 1000 4 dr sedan front doors. Good nick .. look ok and straight and rust free when I last looked at them. Will check again if someones interested .
$50 pair
9. 202-4203 ARP Head stud kit for A14-15 . A must when trying to boost a big A to keep the head squished down nice and tight
$100
10. A14/15 race engine. Specs can be supplied. Complete with roller rockers and many mods
Has made a lazy 98.7hp ATW with low comp pistons.
$5000
11. Celica T50 5 speed box suit A series. Comes with Dellow bellhousing kit , Toyota 200mm cushioned ceramic clutch and steel billet flywheel.
$1500
Would prefer to sell engine and box as a combo to keep engine balance right with the flywheel and clutch being balanced to engine .Will do engine/clutch box combo for $6000
Sounds alot but you won't build it for less.
12. EFI manifold for oval port A series
Modified "GX - JTS" manifold to take injectors. requires alittle tickle with the die grinder and a coat of silver paint to make pretty
Has injector rail and injectors. I was going to use it on the race motor in a street car with a single TB on the front and a plenum in a turbo application.
$350
Lots more stuff... big shed cleanout... don't be shy... ask.
