Oil pressure
Quite a regular
From Hartswater South Afrika
Hi guys
I am having a oil pressure problem on my a15 motor.If i start it up after its been standing for a day or 2 then i have to rev it up 2 about 2500rpm to get the pressure up.Can anyone help me please
Posted on: 2008/11/20 15:37
Re: Oil pressure
From Bendigo, Victoria, Australia.
Try checking the oil level. if there is enough oil then remove the pressure sender and blow compressed air into it, and watch what your gauge does (or if the light goes out). Oil filter could be partially blocked, remove and replace. If this doesn't solve anything then perhaps remove sump and oil pick up, reseal flange of oil pick up and blow out gause filter. how much oil pressure do you get with the engine running?
Posted on: 2008/11/20 21:05
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
Re: Oil pressure
Quite a regular
Oil level is correct changed the filter twice,I have removed the pick up and the metal filter on the pick up is removed.When it runs the pressure goes to over 5 bar.I am pretty much out of ideas , the motor was overhauld and it was fine for a while then this problem showed up
Posted on: 2008/11/21 17:06
