ca18det help!!
From the central coast, nsw
full ova it guys, no injector pulse, no spark!! done my own wiring triple checked it all got my boss to triple check it all wiring is good! just wonderin if i can get a shine of light by anyone who has done there own wiring n the ca18det has or hasnt got injector pulse n found ways to fit it!! was thinkin of just rippin the wiring out n puttin a micro tech in it!! n yes the crank angle sensor is workin, if tested it n swapped it.. n there is power to the injectors just no pulse please help with some ideas guys..
Posted on: 2008/11/27 10:47
Re: ca18det help!!
you haven't given heaps of info so this is all I've got
- Is there power to the ecu while cranking? I've seen people accidently power the ecu with the accessories power so it loses power when you are cranking.
-Are your relays ticking over when you power up the ecu?
-All earth wires connected? There are 2 that come out of the engine loom and attach to the top of the inlet manifold that are important, Also is the engine earthed properly?
good luck
Posted on: 2008/11/27 10:51
Re: ca18det help!!
yer thanks man!! all wiring is correct! all earths are attached!! followed all my wiring diagrams n wired all up! just the triggerin side of things isnt working!
Posted on: 2008/11/27 10:57
Re: ca18det help!!
check the ignitor box as well could be stuffed, i had the same problem n my ignitor box wasnt earthed properly
Posted on: 2008/11/27 10:59
Re: ca18det help!!
Re: ca18det help!!
hmm lol sorry man thanks for the idea but it worked on another car cause i was diagnoisin a problem wid it n used mine so its in good workin order lol keep the ideas comin please might be something i missed!!
Posted on: 2008/11/27 11:06
Re: ca18det help!!
From Sydney, Australia
Use a new battery.
<12v means the car purposely won't start.
Also replace the CAS. The sensors after 20 years are getting flakey.
Neutral switch etc doesn't affect spark. The debugging guides in the factory manual will tell you this.
If you've checked everything else...please put the battery on the charger overnight, and try again tomorrow.
ps (edit) also check you are still getting 12v at the ECU during cranking. As I'm sure you are aware, the 1200 has 2 terminals for ignition, one for cranking, and one for running. Please bridge these two, to create an ignition always pin.
Posted on: 2008/11/27 12:03
Re: ca18det help!!
From Canberra
Which computer are you using?? stock CA or aftermarket?
And how'd you do the wiring check?? Visual or did you check the continuity of the wires with a electrical meter?
Posted on: 2008/11/27 21:58
Candy Apple Red CA18DET Ute
Re: ca18det help!!
yer thanks for that datto dude!! yer i checked the wires visual n for ohms at ecu, n continuity, bak probed wires to dionosis on the s13 workshop manual using stock ecu atm but really tempted to throw a micro-tek in it!!
Posted on: 2008/11/28 7:58
Re: ca18det help!!
From Mandurah, Western Australia
The injectors are switched on via separate earth pulses from the ecu. It is actually possible to touch these wires to earth quickly and force the injectors to click / work. It is common for CA injectors to stick closed is the motor has not been started for a while.
If you are using stock fuse box also check the EGI fuse and relay is are working, Also the IGN relay. his are interlinked and feed volts to coils and injectors.
Makes more sense if you have schematic of CA engine.
If all this checks OK, try your ecu in some one elses car. But I would check that the 12 volt feeds are getting to coils and injectors.
Posted on: 2008/11/28 13:15
(1) 2 3 »
