gearbox bearing part number
Not too shy to talk
From Perth, Western Australia
Hi All,
i've finally got my busted four speed out and as was suggested the layshaft bearing has disintegrated. All the teeth are ok! Does any one know the part number for the two bearings on the layshaft? The one that is completely gone is the one on the carrier plate.
Thanks
Posted on: 2009/2/22 12:02
Re: gearbox bearing part number
From Geelong, Vic
should just be able to go to a bearing supplier and they should be able to tell you
or pull the box apart and read the number off the bearing
Posted on: 2009/2/22 12:16
