Soda blasting V's sand blasting???
Well I want to know the pro's and cons. I want to get my engine bay done on the ratvan. Don't want to spend a crapload on the job. Whats the go?
Posted on: 2009/3/17 8:04
Re: Soda blasting V's sand blasting???
From Nyngan, nsw Australia
flip a coin............0
Posted on: 2009/3/17 8:17
living is good,.....
From sydney
ask datto1000wagon! he thinks he knows everything!!!
Posted on: 2009/3/17 8:19
now now.......i opp to sodablasting ....
Posted on: 2009/3/17 8:37
From newcastle, NSW
Whoa!!!! i just read the other thread and it seems to be getting a little nasty! but this is my opinion of the subject......
Sandblasting is generally used in fabrication workshops as a way of cleaning a surface from thick scaley rust and bits of slag and other imperfections and impurities like oil and flux, it is also very messy and has to be cleaned otherwise it can premote rust.
Sodablasting is good for getting paint off a surface without leaving so much as a scratch on the steel, it leaves a really nice finish for painting, just got the brother-in-laws ute soda blasted and it came up so nice.
Personally i would use soda blasting, but it all come down to price and availablity. IT set the brother-in-law back $550 for the whole car to get done, inside and out. the same job i'm guessing if you had a mate who did sandblasting it could cost as little as a carton of beer and be done on the weekend, when the boss isn't around of course!
But if its only a little area just go out and buy a flap disk or two, and get stuck in!!! put some beer on ice and get a couple of the boys around and get a couple of grinders going, have a whole car done in no time!
Posted on: 2009/3/17 8:38
From Melbourne ( West )
I've heard soda blasting is better.
But, It depends on what your trying to get rid of.
When I got my ute, the previous owner had chemically stripped it to bare metal then left it outside in nice Melbourne weather for a few months.
So I had surface rust and minor pitting all over.
Apperently anything other than sand blasting was no good for this - but special care had to be taken with sand blasting the extreemly thin Datsun panels. (find someone really good that actually cares).
I used Yarra Valley Blasters and can't speak highly enough of him - Top bloke, did a top job for a good price.
Posted on: 2009/3/17 8:45
'78 Ute CA18det Project
No matter where you go... There you are
From newcastle, NSW
yeah it depends on how much and thick the rust is, Some applications need sandblasting. If your just removing paint go for the sodablasting, costs more but leaves the surface nice for fresh painting!
Posted on: 2009/3/17 8:56
From Albany, Perth Australia
soda blasting is heaps better and doesnt damage anything unlike sand blasting. it is well worth it in the end and can evern leave glass on and chrome as it doesnt damage anything
Posted on: 2009/3/17 9:01
1200 Smerf Mobile
From Armidale N.S.W
the fish in the ocean arent thirsty
Posted on: 2009/3/17 9:06
73 1200 wagon SOLD
From Ballarat Victoria
If there is any surface rust Sand blasting is the go. otherwise i`d go soda.
With sand blasting, it is rare to use sand. most use garnet (including myself). Garnet comes in several grades just like sandpaper and i use 80 grade and the local panelshops are more than happy with the finish on panels and parts.
I use glass beads on aluminium and plastic beads are also available.
Edit: The main benifit of using a fine grit over soda is it leaves a fine texture on the metal which gives the primer something to hang onto.
Posted on: 2009/3/17 9:18
VIC DYNO HIRE
(1) 2 3 »
