WTB: 1000 coupe gutter section in boot
From Sydney
Fixing some rust in the boot of my 1k coupe. I need a section of gutter where the boot rubber sits in under the back screen. If anybody has a shell in sydney thats not much good for anything else I would love to come and cut a bit out.
Maybe 1000 sedan or 1200 would be the same? I could use anything
Posted on: 2009/5/7 11:49
Re: WTB: 1000 coupe gutter section in boot
From Sydney
Maybe something from outerstate, if you dnt mind cutting it out and posting. At my cost of course
Posted on: 2009/5/7 14:18
Could you fold a bit of flat sheet up?
Generally for areas like that the rubber seal moulds into whatever it is pressed against so you wouldn't neccessarily need that 'precise' a profile.
Posted on: 2009/5/7 15:01
From Sydney
I will most likely bend up some sheet. I have not had much experiance with this sort of stuff and I thought that getting another section would be the easiest way.
What thickness sheet would you recommend?
Posted on: 2009/5/8 0:22
From SA
1-1.2 mm zink, will be fine
cheers
Posted on: 2009/5/8 1:02
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
