R31 fuel tank
From Brisbane
Hey guys I have tried to search in the wiki but everytime I hit search it crashes on me... Anyways, I have installed a r31 fuel tank into my ute and am plumbing it in. If your looking at the top of the tank with the 2 lines facing at you from the pump which is the supply and which is the return?
Cheers
Dan
Posted on: 2009/10/14 13:00
If you want more inches, stroke it
Re: R31 fuel tank
From Christchurch
just unbolt the pump and pull it half out. It will be prety obvious which is which, the return is the pipe that doesn't have a fuel pump on the end :)
Posted on: 2009/10/14 21:43
Re: R31 fuel tank
From Townsville, Qld
so they're both the same size pipes I'm guessing
Posted on: 2009/10/15 1:42
Re: R31 fuel tank
From Brisbane
Yeah they are both the same size pipe... And I was hopeing to not have to pull the tank out again but I may have to I guess
Posted on: 2009/10/15 2:06
Re: R31 fuel tank
From Christchurch
Put power to it and connect some hose to them and run into a bucket and see which one spits fuel out.
Posted on: 2009/10/15 3:04
Re: R31 fuel tank
From Brisbane
Ok I have been told that the pressure side is the one closest the outside of the tank... I'll try it out and see how it goes I suppose... Thanks guys!
Posted on: 2009/10/15 3:12
Re: R31 fuel tank
From mittagong
im sure you have heard of a guy named Kev Rowlie i dont have his number on me but i can get it if you want? he knows everything about this stuff. (r31 tank & ca18)
Posted on: 2009/11/21 12:51
datsun 1200zx coupe (youll love it)
1200 wagon stock but classic
Re: R31 fuel tank
From Brisbane
Yeah he sorted it out for me...
Posted on: 2009/11/21 18:14
