Wanted 1000 guards
My 1970 4 door 1000 sedan is in at the panel shop getting some serious rust repairs sorted. The verdict is that my original guards are probably past saving. Does anyone have a pair of front guards available for sale? (straight and rust free). I am located near Geelong so am able to pick up from Melbourne, Ballarat, etc but can also organise freight if needed. Any help is gratefully appreciated.
Posted on: 2009/11/25 11:19
Re: Wanted 1000 guards
From gold coast QLD.
Looking at the photos Rat,i'd be inclined to re build the bottom 300mm or so out of some .6 or .8 zincaneal sheet,i've done it several times with good success and very little bog(i'm no panel beater)and a bit of stuffing around.The front of the guards look good and this is the problem area if damaged or rusty.Good B10 guards are as rare as rocking horse manure and cost a motza if you can find any.
Another option is to get a pair of glass guards,there was some one on this site looking at them some time ago,a bit of research and questioning should give a result but i remember thinking at the time they where not cheap.
Posted on: 2009/11/26 6:12
what do you recon a set would fetch?
Posted on: 2009/11/26 22:30
Posted on: 2009/11/26 23:40
Here are the fiberglass guards.
Classic Mini
I have a set here but they certainly aren't the best. See how you go with the Victoria side (to keep your costs down) then PM me about what I have available.
Posted on: 2009/11/27 3:55
Edited by clyons8 on 2009/11/27 4:14:48
EDIT: When I said I had a set here, I meant of the stock steel type. Not the FG ones.
Posted on: 2009/11/27 7:01
