steering arm question
From syd
hey guys, does anyone know if stanza and 200b steering arms are interchangeable?? or even identical??
thanks, adam.
Posted on: 2010/10/15 6:40
Re: steering arm question
From sydney australia
Stanza & 200B steering arms are different. the taper on the ball joint hole is slightly larger on the 200B, but is the same angle, so the 200B steering arm sits down lower on the ball joint. You need a spacer between the nut & the steering arm. The hole is also offset towards the inside of the car, so you get a wider track & more negative camber out of the 200B arm. You have to use a 180B outer tie rod end with the 200B arm, it has the same thread as the Stanza tie rod, & the same size hole for the tie rod end. So you can use the 200B arm with a 180B outer tie rod end on a Stanza & get more negative camber. The same struts will bolt onto both steering arms.
Posted on: 2010/10/17 0:39
