Ported GX cylinder heads.
From St. Louis, MO USA
I have the following ported GX cylinder heads for sale. [I will try to post a picture or a link to pictures.]
ZEK001 SOLD
ZEK002 is a complete GX cylinder head starting with a new GX head. It has 8mm stem diameter stainless steel valves that are 38mm/30mm. The head is unmilled at 2.912" thick. The ports have not been ported as you can still see the casting marks. It has dual Datsun Competition springs and slightly used Datsun competition aluminum valve spring retainers. $750 USD.
ZEK004 is a complete GX cylinder head that is used in running condition as removed from a race engine. It has a PINHOLE WATER LEAK near the top of the cylinder head near the #3 cylinder water plug. The valves are titanium 8mm stem diameter, 39mm and 33mm. It has Crower titanium valve spring retainers and dual competition valve springs. It is a complete cylinder head that was ported and enlarged. Normally without the pinhole leak $1200 USD. With the pinhole leak $800 USD.
ZEK003 is a complete GX cylinder head that is fresh from the machine shop after a race season. Valves are 8mm stem stainless steel, 40mm and 32mm diameter. Retainers are titanium Crower. Dual springs are Elgin cam springs. Thickness of the head is 2.845" and was originally build by Comptech Machine in USA. $1250 USD.
Email is the best way to contact me. Peter
PeterZekert (at) Juno (dot) com
Posted on: 2011/4/12 17:18
Edited by pjz on 2011/4/14 16:15:50
Re: Ported GX cylinder heads.
Valve Train Pieces:
I also have used titanium valves, with smaller 7mm stem diameter, in the following sizes: 33mm exhaust; 37mm and 38mm intake. $10 USD each. [I have every size of stainless steel valves too, but rarely do I have sets of 4 valves. With these titanium valves I have about 8-9 valves in each size.]
SOLD JB Racing roller tip aluminum rockers, all in 1.50 ratio. Set of 8 for $280 USD.
2 sets of stock bushed rockers, polished exterior, $75/matching set of 8.
Titanium valve spring retainers for larger 32mm outside diameter dual springs. Retainers $15 each. Springs, $10 each. Spring cups with aluminum spacers for the head spring seat area, $10 each. [If you want to purchase springs, retainers and cups in a set of 8, I will give a discount or ship them for free.]
These small items are not expensive to ship worldwide. Peter
Posted on: 2011/4/12 18:57
Edited by pjz on 2011/4/13 20:41:54
Edited by pjz on 2011/4/14 3:22:03
Edited by pjz on 2011/4/14 16:16:32
SELLING FOR A COMPETITOR: A collection of ported H89 and GX cylinder heads with titanium or stainless valves, titanium retainers, large diameter dual valve springs, bronze guides, beryllium valve seats, and some with ARP rocker tower hardware and/or with custom rocker towers.
BURKE001 a new, bare H89 cylinder head with 8mm steel guides and new beryllium valve seats for 32-33mm exhaust and 39-40mm intakes. Machined at the rocker tower base for custom rocker towers (towers included), $450 US.
BURKE002 a used H89 ported and polished cylinder head with 7mm valve guides, 38mm titanium intake and 31 exhaust. Crower titanium valve retainers, large 32mm diameter dual springs, ARP rocker tower studs to fit stock rocker towers. 2.843 inch thickness. $1100 USD.
SOLD - BURKE003
BURKE004 a used GX ported and polished cylinder head with 7mm valve guides, 38mm titanium intake and 33 exhaust. Crower titanium valve retainers and large 32mm diameter dual springs. 2.816 inch thickness. Custom rocker towers and rocker shaft included. $1100 USD.
BURKE005 a used GX head with a few nicks in the combustion chamber. It is a running head, same as BURKE004, except without the rocker towers and shaft. Discounted $800 USD.
Peter
Posted on: 2011/4/12 19:11
Edited by pjz on 2011/4/13 20:40:27
Edited by pjz on 2011/4/14 16:17:14
From Brisbane
Email sent.
Posted on: 2011/4/12 22:02
Lotsa great stuff!
Posted on: 2011/4/12 23:02
From Rosewood, QLD
so much good head
Posted on: 2011/4/12 23:44
1971 B110 sedan project.
2012 Nissan Micra daily.
