Re: BIGE "CLEAN UP" ENGINE PARTS SALE/ENGINE REBUILD KITS
From sydney.nsw
I GOT "HEAPS" OF ENGINE PARTS NEW AND USED
A12/A14/A15 ENGINES/HEADS/CRANKS/STD CAMS ETC. SUITABLE FOR RECON(OR CAN BUILD ONE TO SUIT YOU)TO MUCH TO LIST, LOCATED IN SYDNEY FOR PICK UP. IF YOU NEED SOMETHING GIVE ME A CALL ERNIE 0412 864 741 NEEDS TO GO TO MUCH THERE PRICED TO GO. CHEERS
Posted on: 2011/6/11 3:28
Edited by bige on 2011/6/14 10:21:19
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Quite a regular
hi mate
any twin weeber/dello/mikuni/sus and manifolds to suit h89 oval port heads?
chees
Posted on: 2011/6/11 3:58
gathering bog dust in the "DATCAVE"-
1200 coupe a14 quad carbd dished wats daily project
1200 ute ca18det,minitubs,irs,flared,ssr mrk3 dished jdm custom project
1600 sedan l18 supercharged mrk 2s, fender mirrord daily
mazda b1800 pickup v6 bike h...
From sydney.nsw
NO, got (2) 32/36 webbers missing minor bits(sold), one has adapter.also got 4 bolt round port & oval port inlet manifold
still getting into the piles of stuff. 4 new ute rear blinkers 3 chrome 1 black.
Posted on: 2011/6/11 4:05
Edited by bige on 2011/7/11 10:59:52
From sydney.nsw
1st list; A12 +060cast pistons & rings flat tops(NEW) $240
A15 +040cast pistons & rings dish (new) $250
A15 +060 cast flat top pistons & rings & conrod combo(new)
(rods have been bushed/new bolts & balanced.this is a floating little end set up,also has pin buttons)$550
A15 USED forged flat tops pistons &
rings(77.5mm)with valve reliefs on shotpeened rods. (note; 1 piston has marks in crown of piston.didn't affect it (also have used block to suit & used knifed egded a15 crank(need linish) 060pins/040maims to suit (can supply new bearings)ex race engine be a good sh##ter as builder say haha. cheers
USED A14 Lightened/Knife edged & indexed crank 040pins/010 mains ( measures good,just needs a linish)$300 (SOLD)
0412 864 741 or pm
Posted on: 2011/6/12 2:55
Edited by bige on 2011/6/12 4:19:09
Edited by bige on 2011/6/12 4:32:15
Edited by bige on 2011/6/12 4:33:36
Edited by bige on 2011/6/12 4:43:42
Edited by bige on 2011/6/12 5:18:41
Edited by bige on 2011/6/12 9:55:51
Edited by bige on 2011/6/12 9:57:45
Edited by bige on 2011/6/14 1:16:12
Edited by bige on 2011/7/11 11:00:56
From sydney.nsw
A series "MAGNETO" in good working order $500
1 used electonic dizzy unknowm works(sold)
Posted on: 2011/6/12 4:36
Edited by bige on 2011/6/12 9:56:41
Edited by bige on 2011/6/12 9:58:05
Edited by bige on 2011/6/13 3:55:39
Edited by bige on 2011/6/13 4:31:21
Edited by bige on 2011/6/13 4:33:47
Edited by bige on 2011/7/11 9:38:06
Edited by bige on 2011/7/11 10:57:11
From sydney.nsw
HEADS; USED H89's (suit reco)
H75 used suit reco ported/double valve springs/72mm thick
Posted on: 2011/6/12 10:24
Edited by bige on 2011/6/20 5:44:47
Edited by bige on 2011/6/20 11:12:49
From mandurah
freee bump
Posted on: 2011/6/12 13:08
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From sydney.nsw
crane dizzy sold.thanks
Posted on: 2011/6/13 4:32
do u have any a14 or a15 heads or sunny gearboxes.
Posted on: 2011/6/13 5:30
From Near Bundaberg QLD
Have you got any standard (73mm bore) A10/12 flat tops?
Posted on: 2011/6/13 5:36
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
(1) 2 3 4 »
