Replacement ute panels
From Near Bundaberg QLD
Where is the best place to get replacement panels for utes?
What panels are available?
Does anyone know of any places that have made other sections for you, and what did they charge for said parts? Doesn't have to be for a ute, sedan, or even a datto, just trying to find out some prices on custom repair sections. There's a hot rod resto place in Tiaro QLD which makes custom repair sections but they charge a fair bit.
My ute already has a new tailgate and front apron. I just need some bottom corners made up for the windscreen hole (a patch which replaces an area within a 75-100mm radius of the corners of the windscreen)
The sills need replacing, from the back of the cab to the front of the rear wheelarches. I need to cut off and replace the drip rails and repair the a-pillar and roof where they were attached. The rear seat supports have been removed completely and the front seat supports have been butchered to fit racing seats (previous owner's doing, I'm going to be fitting standard 1200 wagon seats without headrests).
I also need to cut out the floor of the tray and buy a sheet of 1.2mm and get some ribs rolled into it similar to what they have from the factory. I need to somehow replace or repair/straighten the chassis rails/subframes which extend back from the firewall under the front floor pans. The front floor pans are ok, they just need a bit of patching up, but i might have to just fork out for new ones because they will need to come out to repair the rails/frames underneath. Does anyone have any suggestions on how to support/reinforce the body properly so that when the floors and such are removed and the new sections are welded back in, the body isn't all sagged/twisted?
Posted on: 2011/7/9 11:40
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
Re: Replacement ute panels
Additionally, has anyone bought sections and parts from these sellers, and how well did they fit?:
http://shop.ebay.com.au/hermitcrab38/m.html?_trksid=p4340.l2562
http://www.ebay.com.au/itm/DATSUN-120 ... ories&hash=item5644f4daf3
Posted on: 2011/7/9 11:42
From Melbourne, Australia
Hermitcrab is actually wayne080866 off this website. His work is brilliant. The other supplier I can't speak for.
I got priced $600 to make a new floor for the tray of my ute.
Check back a few days ago where I did a post in classifieds for aftermarket replacement panels. It lists the prices of all the available replacement panels from Weatherill Park Panels.
Trust me, once you pull your sills off you will realise you have a whole lot more work to do than you expected!
Good luck!
Posted on: 2011/7/9 12:15
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
Does your mate run/work at that Weatherill Panels place?
Was that just to roll the sheet, or was that to buy the sheet and roll it?
Good luck!
Yeah I found that out when i chopped up my sedan So far the ute doesn't look as bad.
Posted on: 2011/7/9 12:23
1. No, I don't know the guy, as stated in the other post I bought parts off him and they're heaps cheaper than most of them on Ebay. I'd heard reports of non fitting panels off Ebay but what I got from him lined up perfectly.
2. That was to supply and roll the new floor. I just had to weld on the flat part to each end.
Posted on: 2011/7/9 12:42
Current Fleet-
