A12 Turbo power?
Quite a regular
From Hervey bay, QLD
So here is a theoretical i've been wondering about, How much power would a A12 with decent cam, A15 head be able to produce with a blow through turbo set up. With boost coming on From 3500-4000 RPM what kind of turbo on what amount of PSI would create as much power as possible while still being able to have the engine last for 5-8 months daily use? Any oppinions would be appreciated.
Posted on: 2011/7/24 12:26
Re: A12 Turbo power?
From Freo
do some search on here bro, there's a fair bit of info, if you wanted reliable, 100hp at the treads, of course there will be people with more or less.. there are so many variabls
Posted on: 2011/7/24 12:36
A15 PSI Project Motor
'72 CB750k,
From Coondle, WA Australia
i take it this is for either a dyno pony, or the car is destined for the dump.
and that you plan to give the car a hiding.
when you say engine life, ill assume that everything else will cope with the extra torque and HP? else id bet a another part of the drive line will fail.
for such short engine life, you wouldnt bother with any special internals. you could just gamble with any old smoker, although a good internals will give you better tunability. eg better heat management,
max HP its hard to say,but my guess around 120hp before things go to custard real quick
Posted on: 2011/7/24 12:37
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Malaysia
i *think* ive seen a dyno graph of a stock motor here, 128 hp ATW. stock bottom a12 with h89 and stromberg carb. drawthrough setup.
Posted on: 2011/7/24 12:43
Yatala Headworx A12 300hp+ ATW
Sikyne A12 250hp+ ATW (someone confirm?)
Topgear A12 100kw+ ATW
Posted on: 2011/7/24 12:59
From vic
clyons did i read that right a A12 at 300hp??
how reliable?
Posted on: 2011/7/24 13:20
From mandurah
300hp ,that motor wasnt a stocker and is purely a dyno pony ,and was efi with alot of internal work
Alot of money for that type of engine ,would be better off just putting a nice draw through turbo setup on a stocker a12
I thought about it for a while ,but twins sound better haha
Posted on: 2011/7/24 14:43
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Quite a regular
Thanks for that guys you've been very helpful. Yeah its not going to be road registered and i'd just put it in an old banger for some fun depending on how reliable the engine was.
Posted on: 2011/7/24 22:00
From Near Bundaberg QLD
Be better off saving up for an A15 and working it in n/a form IMO.
Posted on: 2011/7/26 12:26
Edited by racer135 on 2011/7/26 13:14:46
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
just draw thru with a water/meth injection setup seems to be the way to go from what i read
Posted on: 2011/7/26 12:33
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
