Hey guys up for sale is my Datsun 180b.
Many of you may remember this as Alex's car and since buying it from him it has sat in my garage doing nothing. It remains exactly as I bought it except without the wheels, but with a CA18 close ration gearbox and with a R180 4.11 rear diff.
Car is unregistered.
Here are the original specs...
Engine:
S15 SR20DE VCT with OEM ecu
Autech 4 into 1 Headers
R31 engine mounts
Lukey Muffler
Drive train:
Standard diff installed but R180 4.11 included.
CA18DET short ratio gearbox.(not fitted)
Suspension & Steering:
Front:
Brand New...
DatSport Handling/Engine fitting kit
Whiteline Bushes
T3 Camber tops
T3 ground Control coilover kit
Eibach 325lb springs
Koni Z31 externaly adjustable inserts
Rear:
1600 Super low Rear King springs (kdrl-02)
Koni Red adj shocks
Brakes & Hydraulics:
DatSport Brake booster & 7/8 MC kit
Wilwood Bias Valve
VR V8 front Calipers
DBA425 slotted rotors
Interior:
Nardi Classic Steering Wheel
Jap SSS Gauge Cluster
RaceTech Smoked Steeper Gauges Oil Temp, Oil Press & Water Temp
Cobra Monaco/Trophy Fixed Back Seats on rails
92 Nissan Exa Rearview mirror
New carpet
Original Tan Vinyl Interior
New window and door seals
Body:
Seam-welded engine bay with 100% paint finish.
Full Re-spray in HO 2pak solid white
MK1 VW Golf GTi front chin spoiler
All chrome trims polished and cleaned
Polished bumper bars
New aftermarket front indicators
New aftermarket side indicators
Lucas semi sealed beams with H1 4000K globes
Wheels and Tyres:
Stocker alloys
Things needed
Possible re-spray (at least front guards)
Wire up ecu
Fuel system (pump available)
Connect exhaust
Flywheel and clutch and fit gearbox
Radiator hoses
Battery
Rear bake lines and handbrake need connecting.
Price $5400 ono
May be interested in a swap or partial swap for running car.
I will also be negotiable if I keep some of the smaller parts, but im mainly interested in selling everything as I need the garage space and believe this car is to good to be parted out.
Car is located in south Sydney. (Sutherland area) I can help arrange postage at buyers expense.
I have more pics if needed, but I believe the value of this car is in the parts and if you are serious then come and have a look.
Contact Matt though pm or on 0415334551 at reasonable hours.
Follow this link for pics -
http://ozdat.com/forum/viewtopic.php?f=53&t=26257
