Ca18det + T28 install
From Sydney
Hey guys I've just installed my T28 of a s14/15 not sure on which one, I was reading somewhere that the stock ca18 afm can only handle 180-190hp not sure if it's true, my point is that I was running 136kwatw on the rundown stock t25 on 7psi which would be around 180hp, I've got custom manifold, 3inch turbo back, 600 x 300 fmic, bov, walbro pump n tank
With this upgrade on stock boost, what ever t28 are, will I gain anymore power? And if I do gain more my afm is out of hp range? Will it lean out, will I need to get a rb25 maf, and how about ecu? Will it also be okay? On stock psi
I will jump the boost up oneday but when I can get a standalone ecu
Thanks guys
If anyone has done this from experience your knowledge is appreciated?
Posted on: 2012/9/16 3:19
Re: Ca18det + T28 install
From Geelong, Vic
the standard afm just wouldnt flow enough air to make more power. so it will just stop making power, it shouldnt lean out
probably wont gain any power going a larger turbo on the same boost, as the t25 should have still been efficient at 7psi
common afm to use is a 300zx one, slightly larger than an rb25 one i think. then you will needto get the ecu tuned to suit
Posted on: 2012/9/16 4:05
