Burning fuse on ignition(reds)
From Gold Coast Queensland, Australia
My 1200 ute was running fine then today it wouldn't start. I noticed the transistor connected to the coil was getting hot. checked the coil setup and fixed. Still burning meter reg fuse. what to do?
Posted on: 2013/1/15 3:26
Re: Burning fuse on ignition(reds)
Transistor on the coil? That is not stock.
Posted on: 2013/1/15 4:19
What to do? Read this: Blown Fuse
Posted on: 2013/1/15 4:22
Sorry mate, its the 'resistor' connected to the coil (white rectangular box). Is it okay to bypass this to test if it will blow the fuse when ignition is turned to on?
Posted on: 2013/1/15 4:50
You can bypass it for about 30 seconds.
Posted on: 2013/1/15 5:14
Thanks ddgonzal, i'll check the wiring diagram and chase down the problem. Cheers for the quick replies
Posted on: 2013/1/15 5:26
