wtb rear shocks 1200 sedan vic
Hopefully.new or near new shocks in vic
Cheers
Posted on: 2013/5/6 14:09
Re: wtb rear shocks 1200 sedan vic
Pm crumb. He might have some new tokico gas shocks for a sedan.
Posted on: 2013/5/6 17:16
Bump
Posted on: 2013/5/22 11:19
From Sydney, Australia
I've got a few sets of NOS kyb (oem standard replacement) for 1200 sedan.
$80 delivered Australia wide.
Posted on: 2013/5/22 14:02
What's the free length on them? Also the size of the bottom bush and hole through it.
I'm looking for shorter shocks for the stanza
Posted on: 2013/5/22 16:30
I'll measure them in a little while.
Posted on: 2013/5/22 22:12
Are they new?
Posted on: 2013/5/23 3:25
They are new, in original KYB boxes with rubber and nuts. Part K6064. NLA from KYB.
They are oil filled KYB branded OEM replacement rear shocks. They are not racing shocks.
Recommended for cars that are relatively standard. Only to suit Datsun 1200 Sedan B110 (rear only).
Between top mounting surface and centre of bottom mount hole.
full length : 528mm
compressed length 362mm
bottom hole : 11mm (for 10mm bolt)
bottom mounting tube length : 32mm.
Measurements taken with the supplied shock bump stops in place.
Posted on: 2013/5/23 5:07
The car is going to be ca18det. What do you recommend dattodude?
Posted on: 2013/5/23 11:40
I recommend you dont go cheap when it comes to rear shocks.
Talk to a suspension place and get a quote. The shocks should be matched to the springs.
I would NOT use these stock rated shocks on a CA project.
Axle tramp will be your biggest enemy.
Posted on: 2013/5/23 11:56
