Best dizzy to run for a15t
From Sydney
Hey guys just wondering what is the best electronic dizzy to run on my draw thru a15 and to be regraphed?
Posted on: 2013/6/10 23:40
Re: Best dizzy to run for a15t
From NSW, Australia
The Pulsar came with the electronic dizzy that works well and you can modify the cog and bracket your self. Check the Tech info here for specific info. ( there are chinese ones on ebay from time to time but im not shore how good they are. maybe some of the members here can comment on these).
The other option is get one made up for you. JTS in St marys uses the EXA/ET turbo dizzy and re graphs it to suit. can be pricey (but the best result of the two).
With out going overboard these would be the two best options imo
Posted on: 2013/6/11 1:15
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
From Townsville, Qld
If you can get a vacuum advance pot that can also retard under boost pressure you will be set, otherwise static timing would need to stay quite low
Posted on: 2013/6/11 1:21
From Sydney
Hey big D how much roughly would u know?
Posted on: 2013/6/11 4:15
You could just lock it if you don't want to spend big bucks, takes just a few minutes to do and costs next to nothing.
Posted on: 2013/6/11 8:58
From Adelaide
Depending on how handy you are the Ford EDIS4 setup is pretty good with a mega-jolt, then you have a completely self tunable spark setup and probably comparable cost to a custom dizzy.
I've just got my EDIS8 working with custom 36-1 trigger wheel fitted in the dizzy housing. This gives me 1 coil per plug and sequential fire but was a fair bit more pissing around. The Tech Wiki has all you need to know to do the EDIS4 conversion.
Posted on: 2013/6/11 10:35
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
