door actuator
if anybody could help me with this it would be greatly appreciated. After somebody slammed the passenger door closed, the door cannot be opened from the outside but can be opened from the inside. I also heard something fall off from the inside of the door. Will i just need a new door actuator or something else?
And where could i get the parts from? Cheers guys.
Posted on: 2014/2/16 3:12
Re: door actuator
Slam is the normal way to close a 1200 door and doesn't cause breakage. Sounds like a part inside was loose and came off. Remove the door panel and put it back.
I have seen the outside handle break before, so inspect it.
See http://datsun1200.com/modules/mediawiki/?title=Doors#Latcho
Posted on: 2014/2/16 3:37
Re: door actuator
cheers mate will have a look at the handle as well
Posted on: 2014/2/16 3:48
