Diff pinion angle
From Port Douglas. QLD
Hi guys,
Got the ca18 in and running. Have been driving it on the sly this past week
to shake out the little things, getting idle and timing right etc etc.
Found a vibration from round 80km+ Pretty sure it's the diff pinion angle.
Car is on lowering blocks in the rear. Realize I'll need a measuring tool but unsure on how to adjust the angle. Adjusting the gearbox angle is not an option..
Any tips appreciated. heard of people using wedges, machining blocks?
Posted on: 2014/9/27 11:45
1200 ute
ca18det
Re: Diff pinion angle
From Melbourne AUS
You could machine your lowering blocks. Our use a wedge to get the right pinion angle
I've done both in the past
Posted on: 2014/9/27 23:21
1973 B110 A12
I had a very nasty tramping situation in my datsun 1000 after I swapped my drag motor in.
I swapped out the standard springs with the modified leaf (re-set) springs from the drag car in to the old fella along with all new urethane bushes, it still trapped like (some tramping thing).
I had all but given up, and changed my driving style to suit. I thought that the pinion angle may be the culprit, so I swapped the drag cars diff (re set 15 or so degrees up) but it was still tramping like a tramping thing.
Turns out (no word of a lie) I had a dream, that the standard engine mounts ( original 1967 items) were to blame.
I got the trusty mig out and whipped up a new solid passenger side mount and trans mount, And shiver me timbers.
It seems so obvious now but hey.
It doesn't take long, or much effort to solid mount your motor (It does vibrate quite a bit at certain revs).
It cured the tramping issue in my car. Maybe you need to swap out your engine mounts out for some stiffer ( urethane or solid items).
Hope it helps.
G
Posted on: 2014/9/28 11:38
Jesus drove a datsun
`67 B10 Turbo white
`69 VB10 red
`71 S30 (240z) orange 432R style
`78 P330 (280c) president matte black
`76 p330 (260c) wagon silver
`96 Toyota Hiace 2.8 diesel LWB
