Browsing this Thread:
Datsun 1200 ute front disc brakes,,
From Leeton NSW
Hey guys im after disc brake front conversion for my 1985 1200 ute mainly keen on 1200 coupe disc brakes have cash waiting so let me know what you have im in leeton nsw 2705...
Posted on: 2015/5/6 9:04
Edited by violi on 2015/5/6 12:25:43
Get in, sit down, shut up and hang on!!!
Re: Datsun 1200 ute front disc brakes,,
From Kelmscott Western Australia
120y the same
I run std master cylinder with no booster with no worries
Posted on: 2015/5/6 11:55
71 Datsun 1200 ute with A14 fuel injection and T50
59 Morris minor ute with A15 fuel injected with intercooled turbo
From Leeton NSW
Ahhkk so only need the discs then dont need to change my standard master cylinder?
Posted on: 2015/5/6 12:26
No need to change the master cylinder. But you need more than discs. Get the entire strut/brake assemblies and bolt them on. 1200 Coupe is the best way to go. See 1200 Disc Brake Swap.
Posted on: 2015/5/6 20:47
From Leeton NSW
Thanks so im after the complete set up as i just bought new shocks so thought id do the upgrade while i have to rip everything out and before my new engine goes in ..anyone selling 1200 coupe front brake setup??
Posted on: 2015/5/7 8:51
Quite a regular
Try and get 120y struts and put 1200 strut top on, that way later you can upgrade to s13 rotors and calipers later
Posted on: 2015/5/7 9:17
S13 rotors & calipers fit the 1200 struts too. See S13 Brakes.
120Y struts are similar, but not the same as 1200 struts:
* top hat differs
* spring length differs
* caliper differs
120Y can be used if the spring & top hat are swapped from the 1200 drum-brake strut. Keep the 1200 drum-brake hubs which can be used in future S13 rotor swap.
Posted on: 2015/5/7 9:21
120y
Change the tops and make sure the lower arm bolt holes are the same cause the centre centre bolt holes are diffrent but if you get the arms with 120y struts its all good
Posted on: 2015/5/7 11:40
Lower arm (LCA) comes in two variety for 120Y. Early is same as B110, Late is same as B310.
The struts do not bolt to the LCA, they bolt to the Steering Arm, so no worries. Just use your existing 1200 LCA and steering arm.
Posted on: 2015/5/7 13:12
WTB: Datsun 1200 ute front disc brakes,,
From Leeton NSW
Bump.. still keen on a the disc break front end..
Posted on: 2015/5/10 12:28
Edited by violi on 2015/5/11 9:39:04
