Datsun 1200 coupe Parts Wanted
Hey guys
Im after a datsun 1200 coupe original nissan black carpet.
Will wait and see if i can get an original carpet in good condition before buying aftermarket.
also after oval port manifold for webers.
I will add on a few more parts im after as i go on.
Thanks in advance
Cheers
Posted on: 2015/12/1 10:18
Re: Datsun 1200 coupe Parts Wanted
Few more parts....
Is anyone selling brake adaptor plates to fit rx7 FC series 4/5 calipers to 120y struts?
If so, im very keen.
I have used the search box but couldn't get any info or write up regarding rx7 series 4/5 calipers to 120y struts.Any info/links will be much appreciated.
cheers
Posted on: 2015/12/2 1:11
Maddat used to sell a kit with the rx7 calipers didn't they? Although I think they might have been FD...
Might be worth asking sssute, seems he still visits the site occasionally.
Posted on: 2015/12/2 2:09
thanks for the info mate,
I already checked but they use the rx7 calipers on the bigger struts.Not the smaller diameter 120y / 1200 struts.
cheers
Posted on: 2015/12/2 2:13
Ah, I must have skipped over that bit. I have't heard of anyone doing that swap onto a 1200/120y strut.
supafatto has some experience with the rx7 verada discs from memory?
Posted on: 2015/12/2 2:58
yeh im hoping he chimes in.
Looking to adapt some rx7 series 4/5 calipers to his 120y coilovers struts.
I will pm him if he doesnt :)
Thanks mate
Posted on: 2015/12/2 5:36
I have rx7 s4/5 stuff on my coupe but they are fitted to custom 51mm struts not 45mm struts.
Posted on: 2015/12/2 5:55
Car free
thanks for your input supafatto,
So i guess i will have to get a custom bracket..
Id prefer to fit them to your 120y coilovers simply because the car came with it.
I haven't looked at the setup properly, but would it require alot of work?
Trying to figure out whether to custom make a bracket or put bigger struts.Would also prefer to use them under 13inch rims.max 14 inch rims...
Are you selling a kit for rx7 calipers to bigger struts just incase i go bigger struts?
cheers
Posted on: 2015/12/2 6:07
I can mate did you buy the white coupe?
Posted on: 2015/12/2 8:15
Car free
I opened a new topic discussing how to fit RX7 calipers to a 120Y strut. See Fitting RX7 calipers to 1200/120Y struts
Posted on: 2015/12/2 9:14
(1) 2 3 »
