Browsing this Thread:
Superboss engine swap
Superboss is GM's answer to the SR20DE engine. 2 liters, 167 HP, 168 lb ft torque. Claimed to be the most naturally aspirated torque/liter for 20 years until beaten by Ferrari 458
1990-1992 Opel Kadett 200 GSi 16V S with 20XE engine (GM Family II engine) using Cosworth or Kolbenschmidt 16V cylinder head
GM Family II four-cylinder 1979-
GM Family I four-cylinder 1982- Ecotec versions available
http://za.tixuz.com/vehicles/nissan/dastun-1400-superboss/1587044
jpg  Superboss 1400.jpg (32.67 KB)
174_56ec8ad37a71e.jpg 640X640 px
jpg  Opel 2.0 .jpg (104.30 KB)
174_56ec944a2fab1.jpg 1023X767 px
Posted on: 2016/3/18 23:48
Re: Superboss engine swap
From melbourne
My brother just fitted a 98 Toyota Altezza Motor in his Galant. It's Aspirated 2.0 L (Beams Motor) RWD claiming Factory 156KW/ 209BHP @ 7500rpm 220NM with a six speed. Goes like #OOPS# off a shovel
Posted on: 2016/3/19 7:20
From Sydney NSW
Ahhh the Family II found in the infamous Holden Camira, had plenty of torque but very unreliable. I'm sure the 16v were an improvement.
Posted on: 2016/3/22 2:44
From Sydney Australia
Actually no, GMH originally specced the cam belt change at 100,000 KM intervals, Good wide tough belt pity about the cheapskate bearings in ths rubbish idler pulley's after many failures fixed under warranty GM did what GM does.
No they did not improve the product they just lowered the belt and pulley change interval to 60,000 KM's.
Yes as a "Race Engine" when you basically throw away most of the factory bits it's a whole new ballgame and surprisingly fast and reasonably reliable but not in stock form.
Posted on: 2016/3/23 9:38
The Camira didn't use this engine (20XE DOHC), but intead an SOHC engine (20LE)
* 1987-1989 Holden Camira JE SOHC
* Plagued by poor Idler design for the timing belt? Or was that earlier Camiras?
* Earlier Camira used smaller engines (1.6 or 1.8), which wer notorious for engine problems as they aged
The 20XE was Opel-designed with head cast by Cosworth or Kolbenschmidt
20XE was succeeded by the Ecotec 20XEV, with Lotus-designed cylinder head
Posted on: 2016/8/23 2:44
Does anyone recognize this engine? Swapped into a Datsun 510, replacing the 1600 engine
Posted on: 2016/8/23 2:46
