jetting specs (sorry)
From durban, south africa
hey guys,
ive just bolted my 32/36 webber on and was wondering if someone could give me jetting specs for that carb.
i have a A-12, wild cam opened up the intake manifold, can rev it to 8k but it hesitates off the line(bogs down) pilots are 45/50 mains are 140/145 and float is set perfect.
can someone please help
many thanks
nicholas
south africa
p.s i am at sea level.
Posted on: 2003/7/15 7:23
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: jetting specs (sorry)
From Brisbane
i run a 135 and 140 on the 32/36 at the moment on my worked a14 try that see what happens
Posted on: 2003/7/15 8:15
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From Little Rock, AR
It sounds like you aren't getting enough fuel, just off idle as the carb shifts from the idle to main circuits. I can't remember much about the Weber DGV's, but if there is a pump jet like the DCOE's/sidedraft carbs, you should increase the size of that jet. That's basically the jet fuel squirts out of, through the accelerator pump when you push the gas down with the engine off. It just bascially needs a bigger shot of fuel when you push the gas pedal. Maybe the DGV's you have to adjust this differently, but in DCOE's/Dellorto's, and even double pumper Holley's it's just a small replaceable squirter on top the carb.
Posted on: 2003/7/15 9:12
