Tailshaft
I have a MR30 skyline box behind my CA18 and also a standard 1600 tailshaft. My question is when I get the tailshaft shortened do I need to get upgraded uni-joints or will the standard ones hold up. Or is there possibly a stronger L-series tailshaft I could have?
Posted on: 2003/7/20 14:26
Re: Tailshaft
From Millgrove Vic OZ
Stock joints are adequate as is the shaft.
Posted on: 2003/7/20 22:30
Cheers Feral
Re: Tailshaft
From brisbane
Dunno if the tailshaft will fit the output from the gear box. IF it does then you are laughing, but i know a stanza taily will fit, just needs to be shortened.
mely
Posted on: 2003/7/21 2:18
Re: Tailshaft
From Arlington, TX, USA
Yes, the 1600 joints are the same ones used in the early Z's (L24/L28). Should handle the torque just fine.
FWIW, the weak link on a 1600 seems to be the joints in the drive axles. Don't know why they fail first, as they are the same joint used in the tailshaft.
Posted on: 2003/7/21 5:33
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
Re: Tailshaft
Its the large changes in drive angle that make them fail.
Posted on: 2003/7/21 11:21
Cheers Feral
