B210 Tachometer
From Datsun 1200 Club
Category: Datsun B210
<-- back to B210 Gauges
Tachometer (rev counter) for Datsun B210.
Datsun B210 tachometer
31149.jpgAlbum 31149
RHD vs LHD
The plastic box (housing) that contains the tacho is the opposite way around. i.e, a mirror image. The bottom tab is offset to one side. Apparently the gauge mechanism differs too since the wires are different.
when viewed from the front
* LHD offset to the left of center
* RHD offset to the right of centre
Right-Hand Drive
15705.jpgAlbum 15705
Left-Hand Drive
One-Wire vs Two-Wire
On a factory tachometer, the BW wire (Black wire with White stripe) is the signal wire. This wiring only matters if you wish to use the factory wiring harness.
  • RHD tachometers use a induction-loop signal wire (two BW wire ends come out of the tacho) — like the B110 unit
  • LHD tachs use a voltage sense wire (one BW wire) like most Datsun tachs starting in the mid-1970s
A one wire tach has ONE black/white wire not two (it also has the red wire and black wire that plug into the instrument circuit board ). I think all RHD 120Y wiring harnesses expect a two-wire tach ... Possibly you can adapt it either by soldering another black/white wire onto the tach (there is a spot), or just putting t-intersection in where the black/white wires connect on your wiring harness so that the tach is connected and the ignition circuit is still closed.
Two-wire RHD (two BW wires coming out of case)
13528_4cc768929f4f8.jpgPost 343652
One-wire LHD (single BW or BG wire coming out)
12134.jpgAlbum 12134
Wiring RHD
The tachometer is wired in series with the coil feed wire. There are two connectors that you pull apart behind the dash and plug the the tach wires into the loop, plus it has an IGN+ wire.
RHD Wiring discussion: POST 120y tacho trigger
28064.jpgAlbum 28064
Wiring LHD
The tachometer is wired to the coil negative terminal. All North America B210s have the tachometer wiring right there in the dash. Since the wiring is in the dash harness, no cutting is needed, and no new wires need to be run out to the coil. Unwrap the tape to reveal the 6-pin connector.
28061.jpgAlbum 28061 28062.jpgAlbum 28062
Just make sure the tach you buy has the adapter harness (mini-harness) included. It is all the red wires and includes two lamp sockets and a six-pin connector.
174_615c0e2bc2d6f.jpgPost 495960 174_615c0e07056fa.jpgPost 495960
1976 BE-49 Tachometer wiring schematic
31152.jpgAlbum 31152
1976 BE-49 Tachometer wiring diagram
31151.jpgAlbum 31151
6-pin rectangle connector
* with divider & two slanted-corners
CONNECTOR on DASH HARNESS
BW  L
RY  B  wire colors
----- [divider]
GY  R
TACH HARNESS CONNECTOR
BG  n/c TACH:BG n/c
RG  B   LAMP	 TACH:B
-----   [divider]
RL  R   LAMP	 TACH:BW
Early (BW wire) one-wire (single BW wire coming out). B wire is grounded to the metal case
28065.jpgAlbum 28065
B210 tach LHD USA
EARLY USA bullet connectors
* B  ground (Black wire)
* R  IGN+   (Red wire)
* BW signal (Black wire with White stripe)
Late (BG wire) one-wire (single BG wire coming out)
174_6156fe4f7ed79.jpgPost 495941
Used tachs may or may not come with the Tachometer Harness, which is used to plug into the Dash Harness. All B210s have the dash harness tach connector, even cars that didn't originally have a tachometer.
Rear three wires plug into mini-harness (all the red wires)
174_6156fecde70fb.jpgPost 495941
Tachometer Harness (mini-harness)
* has two black Lamp sockets
* has BW, B, R, RW and RB wires
* 6-pin connector (connects to Dash Harness)
  one pin not connected
* 3 bullet connectors to attach to Tachometer
1976-1978 with the 6-pin connector
BW Coil-
B Ground
R IGN
1974
BW coil-
B to terminal 'A' on dash
R to terminal 'C' on dash
The signal wire is brought into the dash wiring even if it didn't come with a tachometer originally.
1974-1975: signal is a single wire in the dash harness
1976-1978: 6-pin connector in the dash harness
* 1978 and 1976-1977 CALIFORNIA: signal wire comes from
     the electronic ignition black
     box (which is under the dash)
7484013842_2fe9d680e5_m.jpg 7484011750_0a6072c4f1_m.jpg 7484010102_010584da15_m.jpg 7484008332_69fd5f595d_m.jpg
Tach-Volt Meter
174_5d095bf4bd3b5.jpgPost 491739
JPN 1973-1975
rectangle, 2-tab
  (op.) S-all (exc. 4-GX), Van
    24855-H5000 TACHOMETER
    24860-H5000 TACHO. VOLT METER
    25007-H5000 MASK-tachometer
round, 2-tab
  24855-H5700 TACHOMETER GX
  24855-H5500 TACHOMETER (op.) K-DX, K-GL
  25007-H5500 MASK-tachometer K-DX
NORTH AMERICA
#24855-H6200 ASSY-TACHOMETER OP -0775 [BW wire?]
#24855-H7200 ASSY-TACHOMETER OP 0875- [BG wire?]
25007-H6100 MASK-TACHOMETER
Mask (delete blank/cover) 'DATSUN'
H51	B210GT [RHD GL 4-speed model]
H61	LB210T [LHD 4-speed model]
H62	LB210TRU A13 engine [LHD USA model (1974)]
H72	B210 A12T [twin carb]
24855-H6100
2-wire tachometer
31149.jpgAlbum 31149 31150.jpgAlbum 31150
Datsun 720 tachometer vs Datsun B210 tachometer
720 box says "720 タコ" and "TACO 24855-03W00"
B210 box label says "24855-H6100 METER"
24855-H6200
24855-H6200 USA ASSY-TACHOMETER OP -July 1975 [BW wire?]
Has on top row: '3 4 5 6' (#newer unit has '3 4 5')
24855-H7200
24855-H7200 USA ASSY-TACHOMETER OP August 1975- [BG wire?]
Has on top row: '3 4 5' (#older unit has '3 4 5 6')
see more photos POST Datsun B210 Tachometer
174_615c0e9a83bf2.jpgPost 495961 174_615c0eaccb8ba.jpgPost 495961 174_615c0ecd1a27f.jpgPost 495961
LHD
174_6156fd2c21b48.jpgPost 495941 174_6156fd41323bc.jpgPost 495941
174_6156fe4f7ed79.jpgPost 495941 Tachometer_B210_front.jpg 12133.jpgAlbum click to view
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=B210_Tachometer"
This page has been accessed 13,238 times. This page was last modified 07:38, 5 November 2025. Content is available under Datsun 1200 Club.
