Engine Plate
From Datsun 1200 Club
Category: Transmission
The engine plate was used to combat noise, vibration and harshness (NVH). The optional stiffening brackets further reduced NVH.
See Also
* Engine Plate Part Numbers
* Usage of Engine Plate
3.5mm rear engine plate (between engine and transmission), used by some (but not all) A-series engines
21463.jpgAlbum 21463
The plate is only used by certain combinations, for example with a short transmission (56A or 60-series) and short Release Bearing sleeve.
The plate is in no way required, but it does affect which release bearing sleeve is required. The plate can help with NVH, but it is not needed. E.g. you can use a long bearing sleeve with the 56A and leave the plate off. For more details see Release Bearing Sleeve.
B110
Instead of an engine plate, B110 used a dust cover to cover the lower portion of the transmission front cover.
Main: Dust Cover
Starting with B120 Datsun 1200 Truck and B210 the rear engine plate (instead of dust cover) was introduced to cover the transmission.
13659.jpgAlbum 13659
  • B110 - not used with 3-speed or 56L 4-speed
  • B110 - 56A 5-speed uses plate
  • B120 - early, no plate used (through '73-8)
  • B120 - from '73-9 plate used with LB, but not Short Body
  • B210 - 30411-H5001 < 30411-H5000
  • B310 - plate used
  • 30411-H5000 PLATE-engine rear B110 GX-5
  • 30411-H5000 PLATE-ENGINE REAR B120 SB (from '73-9)
  • 30411-H5001 PLATE-ENGINE REAR B120 SB (from '73-12)
    20532.jpgAlbum 20532
  • 30411-H5001 PLATE-ENGINE REAR B210 A12 JDM 1973-1974
  • 30411-H8200 PLATE-ENGINE REAR B210 A14,A12 JDM 1975-1977
  • 30411-H5000 PLATE-ENGINE REAR B210 A13 USA -1173
  • 30411-H5001 PLATE-ENGINE REAR B210 A13 USA 1273-0874
    28764.jpgAlbum 28764
  • 30411-H5001 PLATE-ENGINE REAR B210 A14 USA 0974-
  • 30411-H8200 PLATE-ENGINE REAR B310
Dimensions
The engine plate matches the engine-to-transmission mounting dimensions.
リア プレート
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Engine_Plate"
This page has been accessed 7,670 times. This page was last modified 22:03, 9 November 2025. Content is available under Datsun 1200 Club.
