The "Knuckle arm" (steering arm) is sandwhiched between the Ball Joint and the strut assembly. Datsun knuckle arms come in two basic sizes:
- narrow bolt spacing for 45mm strut tubes (used by B110)
- wide bolt spacing 70mm for 50.8 mm strut tubes (used by most other Datsuns)
Additionally, the size of the taper hole for the ball joint is important.
- B110 and B210 uses the small taper
- Some B310 use a large taper
Then there is the length of the arm -- long arm give a slower steering response, but less effort is required to turn the wheels. Short arms give faster response.
The good news is there is only one size for B110. See the part numbers below.
Comparison
It seems only B310 with W5000/W5060 steering arm uses the larger tie-rod ends.
Knuckle Arm
B120 early +H1000/H1025 rod assy H1000/H5000
B120 7510- +H1025 rod assy H7400 -8507 H7440 8508-
B210 early +H5025 H5000 H7400 late van
B210 late +H5025 rod assy H7400
PB210/USA B210 +H5800 rod assy U0101
B310 +W5025 rod assy H7400 regular cars W5000/W5060 power cars
steering arm
40052 = Knuckle Arm RH
40053 = Knuckle Arm LH
Knuckle Arm RH
- B10: 40052-18000 (different from newer models)
- B110: 40052-H1000 <- 40052-H5000
- PB110: 40052-H2501
- B120: 40052-H5000 to 1974, 40052-H7400 (75-8504), 40052-H7440 (8504-)
- B210: 40052-H5000 (74-75 A12)
- B210: 40052-H7400 (1976-up A engine, except USA)
- B210: 40052-U0101 (USA, also PB, also L16)
- B310: 40052-W5000 (All US, all A15, most A14)
- B310: 40052-H7200 (A12, A13, and budget A14 models)
- B310: 40052-W5060 (big engines, 8001-up)
