FICD
Revision as of 00:48, 12 April 2013; view current revision
Fast Idle Control Device (F.I.C.D.) was fitted to Datsuns with factory-fitted Aircon. This means 1979-up models with air conditioning. The FICD raises the idle speed automatically when A/C is ON to respond to the increaesed load.
FICD consists of two parts, a throttle actuator, and a magnetic vacuum switch. The switch is electrically operated off the compressor signal. The switch then lets vacuum go to the actuator, which pulls the carburetor throttle a little (about 100 RPM).
Vacuum Switch
The vacuum switch has two wires:
  • Ground/earth
  • Signal, which goes to the compressor switch
Fast Idle Actuator
  1. Clearance 'C' should be more than 3mm, Engine fully warm, A/C off.
  2. Start engine and set correct warm idle speed (650 RPM in 'D')
  3. Turn A/C ON, in 'N' and adjust engine speed to 800 RPM.
  1. FICD adjusting screw
  2. Lever 'A'
  3. Lever 'B'
  4. Cable lock screw
North America
B310
1979 A14 & A15 models had optional A/C.
Idle Setting
A14/A14 Manual Transmission
  • A/C OFF: 700 rpm
  • A/C ON: 800 rpm
A14/A14 Automatic Transmission
  • A/C OFF: 650 rpm in "D"
  • A/C ON: 800 rpm in "N"
