B110 USA CATALOG RAW LIST PART 1, Raw List 2
10100-H3957 ASSY-ENGINE WITH DRIVE PLATEFOR TROPICAL 10001-H1951 ASSY-ENGINE WITH CLUTCH 10001-H3950 ASSY-ENGINE WITH CLUTCH 10001-H7050 ASSY-ENGINE WITH CLUTCH 10001-H1653 ASSY-ENGINE WITH CLUTCH (COLD AREA) 10001-H1953 ASSY-ENGINE WITH CLUTCH 10001-H3951 ASSY-ENGINE WITH CLUTCH FOR COLD REGION 10001-H7051 ASSY-ENGINE WITH CLUTCH FOR COLD REGION 10001-H3952 ASSY-ENGINE WITH CLUTCH FOR TROPICAL REG 10001-H7052 ASSY-ENGINE WITH CLUTCH FOR TROPICAL REG 10100-H1958 ASSY-ENGINE WITH DRIVE PLATE 10001-H1952 ASSY-ENGINE WITH CLUTCH 10100-H7151 ASSY-ENGINE WITH DRIVE PLATEFOR COLD REG 10103-H7000 ASSY-ENGINE SHORT 10100-H7152 ASSY-ENGINE WITH DRIVE PLATEFOR TROPICAL 10100-H3955 ASSY-ENGINE WITH DRIVE PLATE 10100-H7150 ASSY-ENGINE WITH DRIVE PLATE 10102-H1001 ASSY-ENGINE BARE 10102-H1900 ASSY-ENGINE BARE 10102-H3900 ASSY-ENGINE BARE 10102-H7000 ASSY-ENGINE BARE 10103-H1001 ASSY-ENGINE SHORT 10103-H1900 ASSY-ENGINE SHORT 10103-H3900 ASSY-ENGINE SHORT 10100-H3956 ASSY-ENGINE WITH DRIVE PLATEFOR COLD REG 10101-H3927 KIT-GASKET ENGINE 10101-H3926 KIT-GASKET ENGINE 10101-H3925 KIT-GASKET ENGINE 10101-H1025 KIT-GASKET ENGINE 10101-18027 KIT-GASKET ENGINE 11042-H3927 KIT-GASKET VALVE REGRINED 11042-H3926 KIT-GASKET VALVE REGRINED 11042-H3925 KIT-GASKET VALVE REGRINED 11042-H1025 KIT-GASKET VALVE REGRINED 11042-18026 KIT-GASKET VALVE REGRINED 11010-H2300 ASSY-BLOCK,CYLINDER 11010-H1000 ASSY-BLOCK CYLINDER 12293-18001 BOLT FIXING BEARING CAP 1 11019-32200 PLUG-WELCH 44 CAM BEARING 00933-13500 PLUG-WELCH 35 CORE HOLE 01648-00084 PLUG-WELCH 35 CORE HOLE 00933-15000 PLUG-WELCH 50 CORE HOLE 11021-13200 PLUG-TAPER 12.7 OIL GALLERY 11024-K0100 PLUG-TAPER 12.7 OIL GALLERY 00933-20650 PLUG-TAPER 6 OIL GALLERY 01647-00011 PLUG-TAPER 6 OIL GALLERY 11046-73402 DOWEL-TIMING 5 FRONT COVER 11023-32200 DOWEL-TIMING 5 FRONT COVER 30412-21000 DOWEL-TIMING 9.5 CASE LOCATING 08213-82810 STUD-FIXING FUEL PUMP 08213-84810 STUD FIXING WATER PUMP 08213-84510 STUD FIXING WATER PUMP 08223-81610 STUD FIXING ENGINE MOUNTING BRACKET 12279-18000 SEAL-OIL CRANKSHAFT REAR 12279-18010 SEAL-OIL CRANKSHAFT REAR (NDK) 12279-H1000 SEAL-OIL CRANKSHAFT REAR (NOK) 21045-18000 PIPE-SUCTION WATER PUMP 08931-30410 PLUG-TAPER THRED WATER DRAIN 11037-H1000 NET-STEEL CRANK CASE 11038-H1000 PLATE-BAFFLE CRANK CASE 08310-61214 SCREW-MACHINE 11110-H1001 ASSY-PAN OIL 11119-61000 SEAT-DRAIN PLUG 11128-69200 PLUG-DRAIN 11026-61000 GASKET-DRAIN PLUG 11130-18002 SEAL-OIL OIL PAN FRONT 11131-18002 SEAL-OIL OIL PAN REAR 11132-18001 GASKET-OIL PAN RH 11133-18001 GASKET-OIL PAN LH 08110-61410 BOLT M6 FIXING OIL PAN 1 11025-18000 STUD-LOCATING OIL PAN GASKET 08915-13610 WASHER-LOCK FIXING OIL PAN 1 08911-1062A NUT M6 FIXING OIL PAN 08911-10610 NUT M6 FIXING OIL PAN 11140-H1002 GAUGE-OIL LEVEL 11140-H1003 GAUGE-OIL LEVEL (dipstick) 13035-H1000 ASSY-COVER TIMING CHAIN 13035-18001 ASSY-COVER TIMING CHAIN 13042-18000 SEAL-OIL CRANKSHAFT FRONT 13510-H1000 SEAL-OIL CRANKSHAFT FRONT (NOK) 13083-18001 TENSIONER-CHAIN TENSION SIDE 13084-18000 SUPPORT-TENSIONER TENSION SIDE 08110-62010 BOLT M6 FIXING TENSIONER 11046-73402 DOWEL-WATER PUMP 11023-32200 DOWEL-WATER PUMP 08110-64010 BOLT-HEX 08915-1361A WASHER-LOCK 08915-13610 WASHER-LOCK 13044-18001 GASKET-TIMING CHAIN COVER 10005-H1000 SLINGER-ENGINE FRONT 08110-8161B BOLT-HEX M8 08110-81611 BOLT-HEX M8 13002-18020 SET-BUSHING CAMSHAFT STD SIZE 13005-H1020 SET-BUSHING CAMSHAFT UNDER SIZE 0.75MM 13004-H1020 SET-BUSHING CAMSHAFT UNDER SIZE 0.50MM 13003-H1020 SET-BUSHING CAMSHAFT UNDER SIZE 0.25MM 13002-H1020 SET-BUSHING CAMSHAFT STD SIZE 13003-18020 SET-BUSHING CAMSHAFT UNDER SIZE 0.25MM 11014-H1000 LINER-CYLINDER 500 11012-H1000 LINER-CYLINDER 400 11013-H1000 LINER-CYLINDER 450 11041-H3900 ASSY-HEAD,CYLINDER 11041-H3901 ASSY-HEAD CYLINDER 11041-H3902 ASSY-HEAD CYLINDER 11041-H3903 ASSY-HEAD CYLINDER 11041-H1001 ASSY-HEAD CYLINDER 13212-H0110 GUIDE-VALVE INTAKE 13212-H0111 GUIDE-VALVE INTAKE 13213-H0110 GUIDE-VALVE EXHAUST 13213-H0111 GUIDE-VALVE EXHAUST 11098-18011 INSERT-VALVE SEAT INTAKE 11098-18012 INSERT-VALVE SEAT INTAKE 11099-18010 INSERT-VALVE SEAT EXHAUST 11099-H1010 INSERT-VALVE SEAT,EXHAUST 00933-20650 PLUG-TAPER 01647-00011 PLUG-TAPER 00933-1401A PLUG-WELCH 00933-14000 PLUG-WELCH 14065-B8600 STUD-MANIFOLD M8 08213-82510 STUD-MANIFOLD M8 08213-82810 STUD-MANIFOLD M8 11051-73403 PLUG-BLIND CYLINDER HEAD 13214-73400 RING-SNAP VALVE GUIDE 00931-30610 PLUG-HEATER OUTLET HOLE 11044-18004 GASKET-CYLINDER HEAD 11044-H1000 GASKET-CYLINDER HEAD 11044-H3900 GASKET-CYLINDER HEAD 11044-H3925 KIT-GASKET,CYLINDER HEAD 11045-H1000 RING-OIL,OIL GALLERY 11056-H1000 BOLT-FIXING CYLINDER HEAD 11056-18001 BOLT-FIXING CYLINDER HEAD 11057-18000 BOLT-FIXING CYLINDER HEAD 11057-H1000 BOLT-FIXING CYLINDER HEAD 11058-18000 WASHER-LOCK FIXING CYLINDER HEAD 1 11058-H1000 WASHER-LOCK FIXING CYLINDER HEAD 1 10005-H1000 SLINGER-ENGINE FRONT 13264-H1000 ASSY-COVER VALVE ROCKER 13264-H7000 ASSY-COVER,VALVE ROCKER 08915-13610 WASHER-LOCK FIXING ROCKER COVER 08360-61612 SCREW-MACHINE FIXING ROCKER COVER 08310-61612 SCREW-MACHINE FIXING ROCKER COVER 15255-B3430 CAP-OIL FILLER 15255-15953 CAP-OIL FILLER 15270-B3400 PACKING-OIL FILLER CAP 15270-11200 PACKING-OIL FILLER CAP 13270-18001 PACKING-ROCKER COVER 21200-A3001 ASSY-THERMOSTAT 82C 21200-A3005 ASSY-THERMOSTAT 88C FOR WINTER 21200-78502 ASSY-THERMOSTAT 76.5C FOR TROPICAL USE 21200-78500 ASSY-THERMOSTAT 82C 11060-G0300 OUTLET-WATER 11060-G0300 OUTLET-WATER 11060-H7000 OUTLET-WATER 11062-58000 WASHER-JOINT WATER OUTLET [gasket] 11062-18000 WASHER-JOINT WATER OUTLET [gasket] 31139-49006 BOLT-HEX M8 08915-1381A WASHER-SPRING 08915-13810 WASHER-SPRING 22120-U2001 ASSY-SWITCH WATER TEMP 24200-H7000 CLIP-SWITCH HARNESS 11810-A3500 ASSY-CONTROL VALVE CRANK CASE EMISSIO 11826-H1000 HOSE-ROCKER COVER TO AIR CLEANER 11826-H1900 HOSE-ROCKER COVER TO AIR CLEANER 11826-H3900 HOSE-ROCKER COVER TO AIR CLEANER 11828-H1001 HOSE-PIPE CONNECTOR TO CONTROL VALV [PCV] 16439-10802 CLAMP-HOSE 16572-10801 CLAMP-HOSE 16572-H7260 CLAMP-HOSE 16572-H1000 CLAMP-HOSE 11830-H1001 CONNECTOR-PIPE 11830-H1900 CONNECTOR-PIPE 11830-H1901 CONNECTOR-PIPE 14920-H1906 ASSY-VALVE CONTROL 14920-H1902 ASSY-VALVE CONTROL 14920-H7101 ASSY-VALVE CONTROL 14920-H7100 ASSY-VALVE CONTROL 14920-H7001 ASSY-VALVE CONTROL 14920-H7000 ASSY-VALVE CONTROL 14920-H1903 ASSY-VALVE CONTROL 14920-H1901 ASSY-VALVE CONTROL 14920-H1908 ASSY-VALVE,CONTROL 14920-H1907 ASSY-VALVE,CONTROL 14920-H1900 ASSY-VALVE CONTROL 14920-H1905 ASSY-VALVE CONTROL 08120-61210 BOLT-HEX M6 08915-1361A WASHER-LOCK M6 08915-13610 WASHER-LOCK M6 B2318-N3300 TUBE-VACUUM L=150 IN TAKE MANIFOLD TO [?] 14917-E4600 TUBE-VACUUM L=150 IN TAKE MANIFOLD TO 14918-H1900 TUBE-VACUUM L=105 IN TAKE MANIFOLD TO 14917-H1901 TUBE-VACUUM L=170 CONTROL VALVE TO CAR 02141-319W0 TUBE-VACUUM L=5000 CONTROL VALVE TO CAR B2318-73002 TUBE-VACUUM L=5000 CONTROL VALVE TO CAR 14917-H1901 TUBE-VACUUM L=260 CONTROL VALVE TO CAR 14917-H1900 TUBE-VACUUM L=260 CONTROL VALVE TO CAR 02141-319W0 TUBE-VACUUM L=155 CONTROL VALVE TO AIR B2318-73002 TUBE-VACUUM L=155 CONTROL VALVE TO AIR 14875-A3000 CONNECTOR-VACUUM TO IN TAKE MANIFOLD 14875-H1900 CONNECTOR 24220-B0100 CLIP-CABLE 14910-A5500 ASSY-VALVE FLOW GUIDE 14910-A5501 ASSY-VALVE FLOW GUIDE 14910-A5502 ASSY-VALVE FLOW GUIDE 14910-H3900 ASSY-VALVE FLOW GUIDE 14910-H3901 ASSY-VALVE FLOW GUIDE 14910-H3902 ASSY-VALVE FLOW GUIDE 14910-N2203 ASSY-VALVE FLOW GUID 14913-A5500 TUBE-EVAPO CONTROL L=200 14913-A5501 TUBE-EVAPO CONTROL L=200 14910-N2200 ASSY-VALVE FLOW GUIDE 14910-N2202 ASSY-VALVE FLOW GUIDE 16439-A0602 CLAMP-HOSE 08120-61210 BOLT-HEX M6 08915-13610 WASHER-SPRING 14911-A5500 TUBE-EVAPO CONTROL(L=80) 14915-H3900 CONNECTOR-3 WAY 16439-A0602 CLAMP-HOSE 22318-C0601 TUBE-VACUUM CONTROL(L=135) 14955-H3900 ASSY-VALVE,VACUUM CUTTING 08120-62010 BOLT 08915-13610 WASHER-LOCK 14956-H3900 ASSY-TUBE,RUBBER,WITH ORIFICE (L=5 14956-H3901 ASSY-TUBE,RUBBER,WITH ORIFICE (L=6 14956-H3900 ASSY-TUBE,RUBBER,WITH ORIFICE (L=5 14960-H3900 CONNECTOR-3 WAY 24220-B0100 CLIP-TUBE 12010-H1011 SET-PISTON WITH PIN STD 12010-H1003 SET-PISTON WITH PIN 0.25 OVER SIZE 12010-H1004 SET-PISTON WITH PIN 0.50 OVER SIZE 12010-H1065 SET-PISTON WITH PIN 0.50 OVER SIZE 12010-H1014 SET-PISTON WITH PIN 0.50 OVER SIZE 12010-H1005 SET-PISTON WITH PIN 0.75 OVER SIZE 12010-H1006 SET-PISTON WITH PIN 1.00 OVER SIZE 12010-H1066 SET-PISTON WITH PIN 1.00 OVER SIZE [-0.40] 12010-H1016 SET-PISTON WITH PIN 1.00 OVER SIZE 12010-H1007 SET-PISTON WITH PIN 1.25 OVER SIZE 12010-H1008 SET-PISTON WITH PIN 1.50 OVER SIZE 12010-H1061 SET-PISTON WITH PIN STD 12010-H1001 SET-PISTON WITH PIN STD 12035-H6201 SET-RING PISTON 0.50 OVER SIZE 12035-B3040 SET-RING PISTON 0.50 OVER SIZE 12039-H6200 SET-RING PISTON 1.50 OVER SIZE 12039-B3040 SET-RING PISTON 1.50 OVER SIZE 12039-H1002 SET-RING PISTON 1.50 OVER SIZE 12038-H1002 SET-RING PISTON 1.25 OVER SIZE 12037-B3040 SET-RING PISTON 1.00 OVER SIZE 12033-H1002 SET-RING PISTON STD 12037-H1002 SET-RING PISTON 1.00 OVER SIZE 12035-H1002 SET-RING PISTON 0.50 OVER SIZE 12034-H1002 SET-RING PISTON 0.25 OVER SIZE 12033-H6201 SET-RING PISTON STD 12033-B3040 SET-RING PISTON STD 12036-H1002 SET-RING PISTON 0.75 OVER SIZE 12100-H1000 ASSY-CONNECTING ROD 12109-H1001 BOLT-CONNECTING ROD (TOKYO RASI) 12109-H1011 BOLT-CONNECTING ROD (TOKAI SEIAT 12112-18000 NUT-HEX CONNECTING ROD 12111-20906 BUSHING-CONNECTING ROD UNDERSIZE 100 12111-20910 BEARING-CONNECTING ROD STD 12111-20900 BEARING-CONNECTING ROD STD 12111-20901 BUSHING-CONNECTING ROD UNDERSIZE 8 12111-20902 BUSHING-CONNECTING ROD UNDERSIZE 12 12111-20903 BUSHING-CONNECTING ROD UNDERSIZE 25 12111-20905 BUSHING-CONNECTING ROD UNDERSIZE 75 12111-20904 BUSHING-CONNECTING ROD UNDERSIZE 50 12200-H1000 ASSY-CRANKSHAFT 12200-H1001 CRANKSHAFT 12200-H1000 CRANKSHAFT 12200-H5000 CRANKSHAFT 00933-20650 PLUG-TAPER 01647-00011 PLUG-TAPER 32202-18000 BUSHING-PILOT 12316-30000 KEY-WOODLUF 5X16 13021-H1000 SPROCKET-CRANK 12301-30000 WASHER-PACKING CRANKSHAFT 12299-18000 SHIM-CRANK SPROCKET 12302-18000 THROWER-OIL CRANKSHAFT 12303-H1001 PULLEY-CRANKSHAFT 12303-18002 PULLEY-CRANKSHAFT 12308-H1000 WASHER-PULLEY BOLT 12309-78200 BOLT-CRANK PULLEY 12310-H1000 ASSY-FLY WHEEL 12312-18000 GEAR-RING FLY WHEEL 12313-10600 DOWL 12315-H1001 BOLT-FLY WHEEL 12331-20300 ASSY-DRIVE PLATE & GEAR 12330-20300 PILOT-CONVERTER 12333-20300 PLATE-CRANK CONVERTER 12315-H1000 BOLT-FLY WHEEL 12212-H1000 SET-BEARING US 1.00MM 12207-M7201 SET-BEARING STD 12207-H1000 SET-BEARING STD 12208-H1000 SET-BEARING US 0.20MM 12209-H1000 SET-BEARING US 0.25MM 12210-H1000 SET-BEARING US 0.50MM 12211-H1000 SET-BEARING US 0.75MM 13001-H7000 ASSY-CAMSHAFT 13001-H1000 CAMSHAFT 11023-78200 PLUG-TAPER 13032-18000 DOWEL-CAMSHAFT GEAR 13010-18001 PLATE-CAMSHAFT 08110-6161A BOLT-FIXING CAMSHAFT PLATE 01111-00022 BOLT-FIXING CAMSHAFT PLATE 08915-1361A WASHER-LOCK FIXING CAMSHAFT PLATE 08915-13610 WASHER-LOCK FIXING CAMSHAFT PLATE 13024-H8500 SPROCKET-CAMSHAFT 13024-18001 SPROCKET-CAMSHAFT 13082-18000 BOLT-CAMSHAFT SPROCKET 13030-18000 WASHER-CAMSHAFT 08915-2401A WASHER-LOCK 08915-14010 WASHER-LOCK 13028-18001 CHAIN-CAMSHAFT 13070-18001 ASSY-TENSIONER CHAIN 08120-63510 BOLT-FIXING CHAIN TENSIONER 08915-13610 WASHER-LOCK FIXING CHAIN TENSIONER 13201-H1000 VALVE-INTAKE 13202-H1000 VALVE-EXHAUST 13203-H1000 SPRING-VALVE OUTER 13205-18000 SEAT-VALVE SPRING 13209-H2302 RETAINER-VALVE SPRING 13209-18000 RETAINER-VALVE SPRING 13209-H2300 RETAINER-VALVE SPRING 13209-H2301 RETAINER-VALVE SPRING 13210-73400 COLLET-VALVE 1 13210-H1000 COLLET-VALVE 1 13210-U0100 COLLET-VALVE 1 13207-18000 SEAL-OIL VALVE (INTAKE ONLY) 13207-H2301 SEAL-LIP VALVE OIL (INTAKE ONLY,KEEPER) 13207-H2310 SEAL-LIP,VALVE,OIL (INTAKE ONLY,NOK) 13219-H1000 SHROUD-VALVE INNER 13219-H1000 SHROUD-VALVE INNER,FOR TROPICAL REG 13252-18000 ASSY-SHAFT & VALVE ROCKER 13254-58000 PLUG-EXPANSHION ROCKER SHAFT 13256-18000 SPRING-INSIDE ROCKER SHAFT 13222-18001 BRACKET-ROCKER SHAFT 13224-18000 BOLT-ROCKER SHAFT 08915-43810 WASHER-PLAIN 13257-18003 ROCKER-VALVE NO.1 13257-18001 ROCKER-VALVE NO.1 13258-18003 ROCKER-VALVE NO.2 13258-18001 ROCKER-VALVE NO.2 13234-18000 SCREW-ADJUSTING ROCKER VALVE 13288-18001 NUT-ADJUSTING ROCKER VALVE 13231-H1000 LIFTER-VALVE 13231-H1001 LIFTER-VALVE 13238-H1001 ROD-PUSH 13238-H1000 ROD-PUSH 14003-H1900 MANIFOLD-INTAKE 14003-H1901 MANIFOLD-INTAKE 14003-H3900 MANIFOLD-INTAKE 14003-H3901 MANIFOLD-INTAKE 14003-H1000 MANIFOLD-INTAKE 08216-62210 STUD FIXING CARBURETOR 14004-H1930 MANIFOLD-EXHAUST 14004-H3931 MANIFOLD-EXHAUST 14004-H3950 MANIFOLD-EXHAUST 14004-H1030 MANIFOLD-EXHAUST 14004-H3930 MANIFOLD-EXHAUST 08213-82810 STUD FIXING EXHAUST MANIFOLD TO EXHAUST 14005-18001 GASKET-INTAKE TO EXHAUT MANIFOLD 14005-18000 GASKET-INTAKE TO EXHAUT MANIFOLD 08110-63210 BOLT INTAKE TO EXHAUT MANIFOLD 01111-00032 BOLT 08915-13610 WASHER-LOCK INTAKE TO EXHAUT MANIFOLD 08911-10810 NUT CYLINDER HEAD TO MANIFOLD 08915-13810 WASHER-LOCK 14037-32200 YOKE-MANIFOLD 14035-K7700 GASKET-MANIFOLD TO CYLINDER HEAD 14035-18000 GASKET-MANIFOLD TO CYLINDER HEAD 14022-18000 SPRING-HEAT CONTROL THERMS 14025-85061 KEY-HEAT CONTROL VALVE 14026-18001 WEIGHT-COUNTER VALVE 14027-36700 WASHER-HEAT CONTROL 14047-36700 SPRING-STOPPER HEAT CONTROL 00933-1101A PLUG-WELCH 00933-11000 PLUG-WELCH 08310-51610 SCREW-SET 14006-18000 PIN-SPRING HEAT CONTROL TO INTAKE MANIF 16174-H1000 INSULATOR-CARBURETOR 16177-H1000 KIT-JOINT SEAT 16174-H3900 INSULATOR-CARBURETOR 16177-H3900 KIT-JOINT SEAT 08915-13610 WASHER-SPRING 08911-10610 NUT-HEX M6 20010-H3100 ASSY-TUBE EXHAUST FRONT 20010-H1020 ASSY-TUBE,EXHAUST,FRONT 20010-H3200 ASSY-TUBE EXHAUST FRONT 20010-H1000 ASSY-TUBE EXHAUST FRONT 20602-27700 NUT-FIXING TUBE END 14011-29901 NUT-FIXING TUBE END 20635-18000 STOPPER-MUFFLER BOUND 20100-H1000 ASSY-MUFFLER WITH REAR TUBE 20100-H7001 ASSY-MUFFLER WITH REAR TUBE 20100-H1800 ASSY-MUFFLER WITH REAR TUBE 20100-H2500 ASSY-MUFFLER WITH REAR TUBE 20100-H7101 ASSY-MUFFLER WITH REAR TUBE 20630-V0100 RING-RUBBER MUFFLER CLAMP 20630-P4400 RING-RUBBER MUFFLER CLAMP 20630-18000 RING-RUBBER MUFFLER CLAMP 20643-B5000 CLIP-TUBE EXHAUST 20620-H1000 CLIP-TUBE EXHAUST 08915-43810 WASHER-PLAIN M8 08915-13810 WASHER-SPRING M8 08110-86010 BOLT-HEX M8 08911-10810 NUT-HEX M8 20640-18000 STRAP-EXHAUST HANGER 42013-0101P STRAP-EXHAUST HANGER 20641-18000 WASHER-PLAIN EXHAUST 08911-10810 NUT-HEX M8 08915-13810 WASHER-SPRING M8 08110-82210 BOLT-HEX M8 20321-H2000 FINISHER-EXHAUST 20321-H2500 FINISHER-EXHAUST 20720-N2226 KIT-SEALANT,EXH TUBE JOINT 20720-N2225 KIT-SEALANT,EXH TUBE JOINT 15010-H9701 ASSY-PUMP OIL WITH OUT OIL FILTER 15010-H6200 ASSY-PUMP OIL WITH OUT OIL FILTER 15010-H1000 ASSY-PUMP OIL WITH OUT OIL FILTER 15020-H1025 ASSY-SHAFT DRIVE OIL PUMP 15020-H1005 ASSY-SHAFT DRIVE OIL PUMP 15025-18003 GASKET-OIL PUMP 15132-H1000 ASSY-VALVE OIL REGULATOR 08310-53010 SET-BOLT BODY TO COVER 08915-13510 WASHER-SPRING 15066-18000 GASKET-OIL PUMP TO CYLINDER BLOCK 08915-13810 WASHER-LOCK 15036-18000 BOLT-OIL PUMP 08110-85510 BOLT 15050-H1000 ASSY-STRAINER OIL 15053-18000 GASKET-OIL STRAINER 08110-82010 BOLT 08915-13810 WASHER-LOCK 15208-55Y00 ASSY-OIL FILTER CARTRIDGE 15208-H1010 ASSY-OIL FILTER CARTRIDGE 15208-13211 ASSY-OIL FILTER CARTRIDGE 15208-13212 ASSY-OIL FILTER CARTRIDGE 16010-H1601 ASSY-CARBURETOR (HITACHI DCG 16010-H1602 ASSY-CARBURETOR (HITACHI DCG 16010-H1600 ASSY-CARBURETOR (HITACHI) 16118-H1000 ASSY-CHAMBER THROTTLE 16145-91460 SPRING IDLER ADJUST SCREW 16145-50000 SPRING THROTTLE ADJUST SCREW 16129-14811 SCREW-THROTTLE ADJUST 16129-25715 SCREW THROTTLE ADJUST 16144-B0815 SCREW IDLE ADJUST 16082-18010 PLATE-ADJUST 16065-10620 SCREW 6D 16065-H1010 SCREW 6D 16029-18010 WASHER 6D 16061-18010 FLOAT 16066-18010 SHAFT FLOAT 16101-H1000 VALVE NEEDLE 16094-10400 WASHER 10D 16098-25710 FILTER 16025-H1000 TUBE EMULSION (P) 16026-25710 TUBE EMULSION (S) 16026-B0810 TUBE EMULSION (S) 16171-25710 WEIGHT INJECTOR 16033-18017 JET-MAIN #92(2000M) 16034-18016 JET-MAIN #86(4000M) 16034-19915 JET MAIN #98 16135-33815 JET MAIN #135 16050-18010 BLEED MAIN AIR #80 16204-08000 BLEED MAIN AIR #100 16213-08000 BLEED MAIN AIR #220 16052-85060 BLEED MAIN AIR #200 16055-14811 JET SLOW #43 16054-B0810 JET SLOW #50 16059-14810 VALVE POWER #60 16455-H1000 KIT-GASKET 16455-H6200 KIT-GASKET 16465-H1000 SCREW & WASHER ETE KIT (A) 16475-H1000 SCREW & WASHER ETE KIT (B) 16134-18010 LEVER THROTTLE 16116-18010 SLEEVE 16133-H1000 LEVER STARTING 16084-58000 WASHER 16084-22010 WASHER 16160-H1001 SPRING-THROTTLE RETURN (FOR 16010-H 16160-H1000 SPRING THROTTLE RETURN 16141-18010 ROD CONNECTING 16272-36710 PLATE DRAIN 16151-H1000 PISTON 16148-H1000 SPRING PISTON RETURN 16307-04000 COVER PUMP 16302-18010 LEVER PUMP 16305-19915 SHAFT PUMP LEVER 16143-18010 ROD PUMP 16011-H1600 ASSY-CHOKE CHAMBER 16011-H1601 ASSY-CHOKE CHAMBER 16248-H1000 ROD CHOKE CONNECTING 16161-H1000 HANGER SPRING 16161-H1001 HANGER-SPRING 16155-B0815 ARM THROTTLE WIRE 16165-H1600 ARM CHOKE WIRE XX010-H1925 KIT-REPAIR A 16009-H1910 KIT-REPAIR A CARBURETOR 16009-H7000 KIT-REPAIR A CARBURETOR 16009-H6200 KIT-REPAIR A CARBURETOR X6010-H1925 KIT-REPAIR A 16009-H1911 KIT-REPAIR B CARBURETOR X6010-H1926 KIT-REPAIR B XX010-H1926 KIT-REPAIR B 16500-H1005 ASSY-AIR CLEANER 16500-H1901 ASSY-AIR CLEANER 16500-H1905 ASSY-AIR CLEANER 16500-H1001 ASSY-AIR CLEANER 16500-H1010 ASSY-AIR CLEANER,FOR COLD REGION 16500-H1015 ASSY-AIR CLEANER,FOR COLD REGION 16500-H1910 ASSY-AIR CLEANER,FOR COLD REGION 16500-H1915 ASSY-AIR CLEANER,FOR COLD REGION 16547-52A00 PACKING 16547-H1000 PACKING A6548-M5600 PACKING 16548-18000 PACKING 16568-H1000 ASSY-PACKING 16546-18000 ASSY-ELEMENT,PAPER(VISCOUS) 16523-H1000 INSULATOR 16547-H1000 PACKING 16596-78521 MARK 01237-00011 NUT-WING 16551-08000 NUT-WING 16551-W7000 16551-H1000 NUT-WING 16525-H1001 STUD-AIR CLEANER 16525-H5000 STUD-AIR CLEANER 16573-H1001 SUPPORT-AIR CLEANER 08915-43610 WASHER-RLAIN 08120-61210 BOLT 08915-13610 WASHER-LOCK 16574-H1001 SUPPORT-AIR CLEANER,FRONT 08915-53610 WASHER-PLAIN A6530-70N40 DUCT-COVER TO AIR CLEANER 16530-H1001 DUCT-COVER TO AIR CLEANER 01555-00291 CLAMP-DUCT 08723-14400 CLAMP-DUCT 16590-H1000 ASSY-COVER,EXHAUST MANIFOLD 16400-H8501 ASSY-STRAINER,FUEL 16400-E3000 ASSY-STRAINER,FUEL 16400-A0600 ASSY-STRAINER FUEL 16440-H1002 TUBE-FLEXIBLE L=200 A8742-20020 TUBE-FLEXIBLE 08742-20020 TUBE-FLEXIBLE 16439-A0600 CLAMP-HOSE FUEL STRAINER SIDE 08723-11500 CLAMP-HOSE FUEL PUMP SIDE 17523-H1900 TUBE-FUEL PUMP TO CARBURETOR 17523-H1901 TUBE-FUEL PUMP TO CARBURETOR 17523-H1902 TUBE-FUEL PUMP TO CARBURETOR 08742-20020 HOSE-FUEL (6X13.3X2.2M) A7515-H1800 TUBE-FUEL FLEXIBLE (6X13.5X5M) 16439-22100 CLAMP-FUEL TUBE 17106-H1001 CLAMP-FUEL TUBE 17106-H1000 CLAMP-FUEL TUBE 17107-H1000 CLAMP-FUEL TUBE 17107-H2300 CLAMP-FUEL TUBE 17108-H1000 CLAMP-FUEL TUBE 17108-M0100 CLAMP-FUEL TUBE 22328-H1002 CLAMP-TUBE VC 31139-49006 BOLT 08915-13810 WASHER-LOCK 08120-61210 BOLT 08915-13610 WASHER-LOCK 17010-H1926 ASSY-PUMP FUEL 17010-H1900 ASSY-PUMP FUEL 17065-13210 ASSY-VALVE FUEL PUMP 17061-50000 GASKET-VALVE FUEL PUMP 17072-01300 RETAINER-VALVE FUEL PUMP 17075-13210 SCREW-RETAINER 17082-18010 CAP-BODY UPPER 17076-18010 DIAPHRAGM-AIR CHAMBER 17089-13210 SCREW-CAP & BODY SET 17090-32200 WASHER-SPRING CAP & BODY SET 17020-85060 SPRING-ROCKER ARM 17053-18010 ASSY-DIAPHRAGM 17053-M0100 ASSY-DIAPHRAGM 17048-18010 SEAL-OIL 17047-18010 RETAINER-OIL SEAL 17052-18010 SPRING-DIAPHRAGM 17010-H1902 ASSY-FUEL PUMP 17010-H1903 ASSY-FUEL PUMP 17010-H1904 ASSY-FUEL PUMP 17076-13211 GASKET 17065-13210 VALVE 17061-50000 GASKET-VALVE 17103-M0800 CONNECTOR-INLET 17103-M0801 CONNECTOR-OUTLET 17013-H2310 COMP-BODY LOWER 17013-H2315 COMP-BODY LOWER 17013-M2000 COMP-BODY LOWER 17020-85060 SPRING-ROCKER ARM 17053-32201 ASSY-DIAPHRAGM 17048-13910 SEAL-OIL 17047-13911 RETAINER-OIL SEAL 17052-37010 SPRING-DIAPHRAGM 17075-M0100 SCREW 17075-13210 SCREW 17089-13210 SCREW 1 17089-M0100 SCREW 1 17090-32200 WASHER-SPRING 1 08915-13810 WASHER-LOCK M8 08911-10810 NUT-HEX M8 00915-41510 WASHER-PLAIN 5/16 17099-21002 GASKET-FUEL PUMP 16420-21000 SPACER-FUEL PUMP 16420-21001 SPACER-FUEL PUMP 08120-61210 BOLT-HEX M6 08915-13610 WASHER-SPRING M6 08723-11400 CLAMP-FUEL TUBE 17201-H1001 ASSY-TANK FUEL 40L 17201-H1902 ASSY-TANK FUEL 40L 17201-H2800 ASSY-TANK FUEL 40L 17201-H1000 ASSY-TANK FUEL 40L 17342-18000 RING-O 17343-14801 PLATE-LOCK 17343-H1001 PLATE-LOCK 17343-14801 PLATE-LOCK 25060-H1000 GAUGE-FUEL TANK 25060-H1900 GAUGE-FUEL TANK 17312-14800 PACKING-DRAIN 17312-H1000 PACKING-DRAIN 17312-P0101 PACKING-DRAIN 17312-P0102 PACKING-DRAIN 17310-H1000 PLUG-DRAIN 17310-P0100 PLUG-DRAIN 08931-44210 PLUG 17251-H1000 CAP-FILLER 17264-18000 PACKING 17220-H1000 ASSY-TUBE FILLER UPPER 17222-H1000 NECK-FILLER 17221-H1000 PACKING FILLER NECK 08310-40812 SCREW 17229-H1900 HOSE-FILLER 17229-H1000 HOSE-FILLER 08723-15800 CLAMP-HOSE A7325-H1000 TUBE(10X14DX5M) 08723-11400 CLAMP-HOSE 16439-22100 CLAMP-HOSE 17335-H1000 TUBE-VINYL 08360-82014 BOLT WITH LOCK WASHER 08915-53810 WASHER-PLAIN 17314-H1000 GROMMET 17201-H1802 ASSY-TANK FUEL 38L 17201-H1801 ASSY-TANK FUEL 38L 17342-18000 RING-O 17343-H1001 PLATE-LOCK 17343-14801 PLATE-LOCK 25060-H1800 GAUGE-FUEL TANK 17312-P0102 PACKING-DRAIN 17312-14800 PACKING-DRAIN 17312-H1000 PACKING-DRAIN 17312-P0101 PACKING-DRAIN 17310-P0100 PLUG-DRAIN 08931-44210 PLUG-DRAIN 17310-H1000 PLUG-DRAIN 17251-H1900 CAP-FILLER 17251-H1000 CAP-FILLER 17264-18000 PACKING 17220-H1801 TUBE-FILLER 17222-H1000 NECK-FILLER 17221-H1000 PACKING FILLER NECK 08310-40812 SCREW-MACHIN 17229-H1801 HOSE-FILLER 17228-H1400 GROMMET 08723-15800 CLAMP-HOSE A7325-H1000 TUBE(10X14DX5M) 08723-11400 CLAMP-HOSE 16439-22100 CLAMP-HOSE 17335-H1800 TUBE 17324-H1400 GROMMET 17334-H1801 CLIP 08510-51012 SCREW 77700-89915 PLUG-RUBBER 30 08110-82062 BOLT-WITH LOCK WASHER 08915-53810 WASHER-PLAIN 74890-H1800 PROTECTOR-FILLER HOSE 08110-62010 BOLT FIXING PROTECTOR 08915-23610 WASHER FIXING PROTECTOR 08915-43610 WASHER FIXING PROTECTOR 08742-20020 HOSE-FUEL STRAINER TO TUBE (6X13.5X2200 08742-20020 HOSE-FUEL STRAINER TO TUBE (6X13.5X2.2M A7515-H1800 HOSE-FUEL STRAINER TO TUBE (6X13.5X5M) 08723-11400 CLAMP-HOSE 16439-22100 CLAMP-HOSE 17501-H1801 TUBE-FUEL 17501-H1001 TUBE (L=378) 17501-H1002 TUBE-FUEL (L=353) 17501-H1100 TUBE-FUEL 17501-H3500 TUBE-FUEL 17501-H3510 TUBE-FUEL 17501-H3900 TUBE-FUEL 17501-H1720 TUBE-FUEL 17501-H3910 TUBE-FUEL 17501-H1120 TUBE-FUEL 24252-36700 GROMMET 24250-89968 GROMMET A7515-H1800 HOSE-FUEL(6X13.5X5M) 08742-20020 HOSE-FUEL (6X13.5X2.2M) 16439-22100 CLAMP-HOSE 08723-11400 CLAMP-HOSE 18010-H1902 COMP-ARM ACCELERATOR PEDAL 18010-H1602 COMP-ARM ACCELERATOR PEDAL 18100-H1602 ASSY-ARM ACCELERATOR PEDAL 18100-H1902 ASSY-ARM ACCELERATOR PEDAL 18017-H1600 PAD-ACCELERATOR PEDAL 18021-H1600 BRACKET-ACCELERATOR PEDAL 18215-H1600 SPRING-RETURN ACCELERATOR 18215-H1601 SPRING-RETURN ACCELERATOR 18137-10600 RING-SNAP E TYPE 08310-S1614 SCREW-MACHINE M5 FOR BRACKET TO BODY FIX 18056-H1600 BOLT-PEDAL STOPPER 08911-30610 NUT-HEX M6 FOR PEDAL STOPPER 18135-14800 BUMPER-ACCELERATOR PEDAL STOPPER 18036-18000 SPRING-CLAMP ACCELERATOR WIRE A8200-G1300 ASSY-WIRE ACCELERATOR 18200-H1600 ASSY-WIRE ACCELERATOR 18410-H1601 COMP-WIRE CHOKE CONTROL 18410-H1602 COMP-WIRE CHOKE CONTROL 18415-H1000 ASSY-KNOB CHOKE CONTROL 18415-H1001 ASSY-KNOB CHOKE CONTROL 00951-10400 GROMMET 21010-18026 ASSY-PUMP WATER WITH GASKET 21010-18027 ASSY-PUMP WATER WITH GASKET 21010-H1025 ASSY-PUMP WATER WITH GASKET 21010-H5025 ASSY-PUMP WATER WITH GASKET BA010-M6626 ASSY-PUMP WATER WITH GASKET 21010-18003 ASSY-PUMP WATER 21022-18003 VANE-WATER PUMP 21026-73000 ASSY-SEAL WATER PUMP 21027-73000 ASSY-SEAT 21035-13202 BEARING-WATER PUMP 21054-18000 HUB-WATER PUMP 21014-18000 GASKET-WATER PUMP COVER 08911-10810 NUT-HEX M8 FIXING WATER PUMP 08110-84810 BOLT-HEX M8 FIXING WATER PUMP 08110-85010 BOLT-HEX M8 FIXING WATER PUMP 08915-13810 WASHER-LOCK FIXING WATER PUMP 21051-18000 PULLEY-FAN & WATER PUMP 21060-H1001 FAN-COOLING 21060-A4605 FAN-COOLING D=330 FOR TROPICAL USA 21060-N0100 FAN-COOLING,FOR TROPICAL USE 08120-62010 BOLT-HEX FIXING FAN 21069-21000 WASHER-COCK FIXING FAN 11720-G0300 BELT-FAN L=838 11720-18002 BELT-FAN L=838 21400-H1900 ASSY-RADIATOR 21400-H1003 ASSY-RADIATOR 21400-H1002 ASSY-RADIATOR 21430-10600 ASSY-CAP 21430-89902 ASSY-CAP PADIATOR 21430-U0100 ASSY-CAP PADIATOR 21480-18000 HANDLE-DRAIN COCK 21481-18000 PACKING-DRAIN COCK 08110-61662 BOLT-HEX,WITH WASHER 21501-H1000 HOSE-RADIATOR,UPPER 21503-H1000 HOSE-RADIATOR,LOWER 21506-H1101 ASSY-HOSE,RADIATOR,LOWER,FORHEATER 21503-H1100 HOSE-RADIATOR,LOWER,FRONT FOR HEATER 21504-H1100 HOSE-RADIATOR,LOWER,REAR FORHEATER 08723-13600 CLAMP-HOSE 27075-H1000 CONNECTOR-HEATER 27075-27700 CONNECTOR-HEATER 21475-H2300 SHROUD-RADIATOR UPPER 21475-H2300 SHROUD-RADIATOR,UPPER FOR HEAVY DUTY S 21476-H2300 SHROUD-RADIATOR,LOWER 21476-H2300 SHROUD-RADIATOR,FOR HEAVY DUTY SPEC 08513-51612 SCREW-TAPPING M5 08915-43510 WASHER-PLAIN 08963-10510 NUT-SPRING M5 11223-H1000 INSULATOR-ENGINE MOUNTING FRONT 11221-H1000 BRACKET-ENGINE MOUNTING FRONT RH 11222-H1001 BRACKET-ENGINE MOUNTING FRONT LH 08915-53810 WASHER-PLAIN FIXING INSULATOR TO 08915-23810 WASHER-LOCK FIXING INSULATOR TO BRACKET 08911-20810 NUT-HEX FIXING INSULATOR TO BRACKET 11321-H1000 ASSY-INSULATOR ENGINE MOUNTING REA 11321-H1020 ASSY-INSULATOR ENGINE MOUNTING REA 11322-H1002 MEMBER-ENGINE MOUNTING REAR 11322-H1020 MEMBER-ENGINE MOUNTING REAR 08110-61410 BOLT-HEX M6 FIXING INSULATOR TO MEMBER 08915-13610 WASHER-SPRING LOCK M6 INSULATOR TO 08911-10610 NUT-HEX M6 08154-02510 BOLT-HEX MEMBER TO BODY FIX 08915-14010 WASHER-SPRING LOCK TO BODY FIX 08915-44010 WASHER-PLAIN M10 TO BODY FIX 11335-18000 BOLT-ENGINE MOUNTING REAR INSULATOR TO 11335-20300 BOLT-ENGINE MOUNTING REAR INSULATOR TO 08915-14010 WASHER-SPRING LOCK M10 08911-14010 NUT-HEX M10 62611-H1000 COVER-UNDER,FRONT 08915-43610 WASHER-PLAIN 08915-13610 WASHER-LOCK 08110-62010 BOLT 16010-H1901 ASSY-CARBURETOR 16010-H1902 ASSY-CARBURETOR HITACHI DCG306-3A 16010-H1900 ASSY-CARBURETOR 16118-H1910 ASSY-CHAMBER FLOAT 16145-91460 SPRING-IDLE ADJUST SCREW 16145-50000 SPRING-THROTTLE ADJUST SCREW 16129-14811 SCREW-THROTTLE ADJUST 16129-25715 SCREW-THROTTLE ADJUST SCREW 16455-H6200 SET-GASKET 16144-B0815 SCREW-IDLE ADJUST SCREW 16082-18010 PLATE-ADJUST THROTTLE 16133-H1000 LEVER-STARTING 16116-18010 SLEEVE 16134-H1910 LEVER-THROTTLE 16236-H1910 LEVER (A) 16116-H1910 SLEEVE (A) 16249-H1910 LEVER 16034-19915 JET-MAIN #98 16135-33815 JET-MAIN #135 16272-36710 PLUG-DRAIN 16059-14810 VALVE-POWER #60 16148-H1000 SPRING-PISTON RETURN 16151-H1000 PISTON 16025-H1000 TUBE-EMULSION P 16026-25710 TUBE-EMULSION S 16026-B0810 TUBE-EMULSION S 16050-18010 BLEED-MAIN AIR #80 16171-25710 WEIGHT-INJECTOR 16055-14811 JET-SLOW #43 16054-B0810 JET-SLOW #50 16011-H1600 ASSY-CHOKE CHAMBER 16011-H1601 ASSY-CHOKE CHAMBER 16204-08000 BLEED-SLOW AIR #100 16213-08000 BLEED-SLOW AIR #220 16052-85060 BLEED-SLOW AIR #200 16098-25710 FILTER 16101-H1000 VALVE-NEEDLE 16066-18010 SHAFT-FLOAT 16061-18010 FLOAT 16307-04000 COVER-PUMP 16302-H1910 LEVER-PUMP 16305-19915 SHAFT-PUMP LEVER 16452-H1000 SPRING-PUMP LEVER 16453-H1000 WASHER (T=2MM) 16155-H1910 ARM-THROTTLE 16161-H1911 HANGER-SPRING 16161-H1910 HANGER-SPRING 16165-H1600 ARM-CHOKE WIRE 16160-H1001 SPRING-THROTTLE RETURN (FOR 16010-H 16160-H1000 SPRING-THROTTLE RETURN 16248-H1000 ROD-CHOKE CONNECTOR 16143-H1910 ROD-PUMP 16141-18010 ROD-CONNECTOR 16262-H1910 DIAPHRAGM-SURVO 16455-H1000 SET-GASKET 16455-H6200 SET-GASKET 16475-H1910 SCREW & WASHER SET B 16465-H1000 SCREW & WASHER SET A 16009-H1910 KIT-REPAIR A CARBURETOR 16009-H7000 KIT-REPAIR A CARBURETOR 16009-H6200 KIT-REPAIR A CARBURETOR 16455-H1000 SET-GASKET 16307-04000 PUMP-COVER 16009-H1911 KIT-REPAIR B CARBURETOR 16009-H7000 KIT-REPAIR A CARBURETOR 16009-H6200 KIT-REPAIR A CARBURETOR 16009-H1910 KIT-REPAIR A CARBURETOR 16475-H1910 SCREW & WASHER SET B 16151-H1000 PISTON 16129-25715 THROTTLE ADJUST SCREW 16129-14811 THROTTLE ADJUST SCREW 16144-B0815 IDLE ADJUST SCREW 16098-25710 FILTER 16101-H1000 NEEDLE VALVE 16066-18010 FLOAT SHAFT 16453-H1000 WASHER 16010-H3901 ASSY-CARBURETOR (DCH306-1A) 16010-H3902 ASSY-CARBURETOR (DCH306-1B) 16010-H7000 ASSY-CARBURETOR (DCH306-4) 16010-H3920 ASSY-CARBURETOR (DCH306-3) 16010-H3921 ASSY-CARBURETOR (DCH306-3A) 16010-H3922 ASSY-CARBURETOR (DCH306-3B) 16010-H7100 ASSY-CARBURETOR (DCH306-5) 16010-H3900 ASSY-CARBURETOR (DCH306-1) 16011-H7011 ASSY-CHAMBER,CHOKE 16011-H3920 ASSY-CHAMBER,CHOKE 16011-H3910 ASSY-CHAMBER,CHOKE 16011-H7111 ASSY-CHAMBER,CHOKE 16182-H3920 POT-DASH 16302-H3910 LEVER-PUMP 16258-H3920 HOLDER-DASH POT 16143-H3910 ROD-PUMP 16262-H3910 DIAPHRAGM-SERVO 16118-H3910 ASSY-CHAMBER,THROTTLE 16118-H3911 ASSY-CHAMBER,THROTTLE 16118-H7011 ASSY-CHAMBER,THROTTLE 16145-91460 SPRING-IDLE ADJUST SCREW 16145-50000 SPRING-THROTTLE ADJUST SCREW 16129-25710 SCREW-THROTTLE ADJUST 16129-25715 SCREW-THROTTLE ADJUST 16114-H7010 SCREW-THROTTLE ADJUST 16144-M0110 SCREW-IDLE ADJUST 16144-H7010 SCREW-IDLE ADJUST 16147-E6600 CAP-IDLE LIMITTEY 16082-H3910 PLATE-ADJUST 16082-H7010 PLATE-ADJUST 16116-H3910 SLEEVE(B) 16128-H3910 LEVER-FIRST IDLE 16249-H3910 LEVER-OPENER 16389-H7010 COVER-THERMO 16389-H3910 COVER-THERMO 16267-H3910 PIPE-VACUUM 16267-H3920 PIPE-VACUUM 16161-H1911 HANGER-SPRING 16161-H7010 HANGER-SPRING 16134-H1910 LEVER-THROTTLE 16134-H3920 LEVER-THROTTLE 16116-H1910 SLEEVE(A) 16236-H1910 LEVER 16452-H1000 SPRING-PUMP LEVER 16453-H1000 WASHER 16025-H1000 TUBE-EMULSION(P) 16160-H1910 SPRING-THROTTLE RETURN 16171-25710 WEIGHT-INJECTOR 16171-H7010 WEIGHT-INJECTOR 16061-18010 FLOAT 16026-B0810 TUBE-EMULSION(S) 16151-H1000 PISTON-POWER 16148-H1000 SPRING-PISTON RETURN 16141-18010 ROD-CONNECTING 16305-19915 SHAFT-PUMP LEVER 16307-04000 COVER-PUMP 16272-36710 PLUG-DRAIN 16066-18010 SHAFT-FLOAT 16101-H1000 VALVE-NEEDLE 16098-25710 FILTER 16029-18010 WASHER 16065-H1010 SCREW 16033-L0101 JET-MAIN #97 16033-H7010 JET-MAIN #95 16043-25715 JET-MAIN #140 16055-14811 JET-SLOW #43 16054-B0810 JET-SLOW #50 16050-18010 BLEED-SLOW AIR #80 16204-08000 BLEED-SLOW AIR #100 16051-H3910 BLEED-SLOW AIR #215 16059-H3910 VALVE-POWER #50 16059-H3911 VALVE-POWER #45 16059-14810 VALVE-POWER #60 16196-H7010 ASSY-CUT,FUEL 16196-H7011 VALVE-ANTI DIESELING SOLENOID 16455-H1000 KIT-GASKET 16455-H6200 KIT-GASKET 16455-H6200 KIT-GASKET 16455-H1001 KIT-GASKET 16475-H3910 KIT-SCREW & WASHER(B) 16475-H7010 KIT-SCREW & WASHER (B) 16465-H3910 KIT-SCREW & WASHER(A) 16009-H1910 KIT-REPAIR A, CARBURETOR 16009-H7000 KIT-REPAIR A,CARBURETOR 16009-H6200 KIT-REPAIR A CARBURETOR 16009-H7010 KIT-REPAIR B,CARBURETOR 16009-H3910 KIT-REPAIR B, CARBURETOR 16010-H3901 ASSY-CARBURETOR (DCH306-1A) 16010-H3902 ASSY-CARBURETOR (DCH306-1B) 16010-H7000 ASSY-CARBURETOR (DCH306-4) 16010-H3920 ASSY-CARBURETOR (DCH306-3) 16010-H3921 ASSY-CARBURETOR (DCH306-3A) 16010-H3922 ASSY-CARBURETOR (DCH306-3B) 16010-H7100 ASSY-CARBURETOR (DCH306-5) 16010-H3900 ASSY-CARBURETOR (DCH306-1) 16011-H7011 ASSY-CHAMBER,CHOKE 16011-H3920 ASSY-CHAMBER,CHOKE 16011-H3910 ASSY-CHAMBER,CHOKE 16011-H7111 ASSY-CHAMBER,CHOKE 16182-H3920 POT-DASH 16302-H3910 LEVER-PUMP 16258-H3920 HOLDER-DASH POT 16143-H3910 ROD-PUMP 16262-H3910 DIAPHRAGM-SERVO 16118-H3910 ASSY-CHAMBER,THROTTLE 16118-H3911 ASSY-CHAMBER,THROTTLE 16118-H7011 ASSY-CHAMBER,THROTTLE 16145-91460 SPRING-IDLE ADJUST SCREW 16145-50000 SPRING-THROTTLE ADJUST SCREW 16129-25710 SCREW-THROTTLE ADJUST 16129-25715 SCREW-THROTTLE ADJUST 16114-H7010 SCREW-THROTTLE ADJUST 16144-M0110 SCREW-IDLE ADJUST 16144-H7010 SCREW-IDLE ADJUST 16147-E6600 CAP-IDLE LIMITTEY 16082-H3910 PLATE-ADJUST 16082-H7010 PLATE-ADJUST 16116-H3910 SLEEVE(B) 16128-H3910 LEVER-FIRST IDLE 16249-H3910 LEVER-OPENER 16389-H7010 COVER-THERMO 16389-H3910 COVER-THERMO 16267-H3910 PIPE-VACUUM 16267-H3920 PIPE-VACUUM 16161-H1911 HANGER-SPRING 16161-H7010 HANGER-SPRING 16134-H1910 LEVER-THROTTLE 16134-H3920 LEVER-THROTTLE 16116-H1910 SLEEVE(A) 16236-H1910 LEVER 16452-H1000 SPRING-PUMP LEVER 16453-H1000 WASHER 16025-H1000 TUBE-EMULSION(P) 16160-H1910 SPRING-THROTTLE RETURN 16171-25710 WEIGHT-INJECTOR 16171-H7010 WEIGHT-INJECTOR 16061-18010 FLOAT 16026-B0810 TUBE-EMULSION(S) 16148-H1000 SPRING-PISTON RETURN 16141-18010 ROD-CONNECTING 16305-19915 SHAFT-PUMP LEVER 16307-04000 COVER-PUMP 16272-36710 PLUG-DRAIN 16066-18010 SHAFT-FLOAT 16101-H1000 VALVE-NEEDLE 16098-25710 FILTER 16029-18010 WASHER 16065-H1010 SCREW 16033-L0101 JET-MAIN #97 16033-H7010 JET-MAIN #95 16043-25715 JET-MAIN #140 16055-14811 JET-SLOW #43 16054-B0810 JET-SLOW #50 16050-18010 BLEED-SLOW AIR #80 16204-08000 BLEED-SLOW AIR #100 16051-H3910 BLEED-SLOW AIR #215 16059-H3910 VALVE-POWER #50 16059-H3911 VALVE-POWER #45 16059-14810 VALVE-POWER #60 16196-H7010 ASSY-CUT,FUEL 16196-H7011 VALVE-ANTI DIESELING SOLENOID 16455-H1000 KIT-GASKET 16455-H6200 KIT-GASKET 16455-H6200 KIT-GASKET 16455-H1001 KIT-GASKET 16475-H3910 KIT-SCREW & WASHER(B) 16475-H7010 KIT-SCREW & WASHER (B) 16465-H3910 KIT-SCREW & WASHER(A) 16009-H1910 KIT-REPAIR A, CARBURETOR 16009-H7000 KIT-REPAIR A,CARBURETOR 16009-H6200 KIT-REPAIR A CARBURETOR
