Also see:
Part Numbers Index Main article for usage, photos, cross-reference Brake Piping
1 46223-H1901 ASSY-TUBE BRAKE MASTER CYL. FR(TANDEM)TO OP 2 46223-H1900 1 46223-H3900 ASSY-TUBE,B/MASTER CYL.FR (TANDEM) TO 1071-0473 30 46223-H1901 1 46223-H3901 ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO 0573- 2 46223-H3900 1 46223-G1300 ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO 0573- 46223-H3901 1 46223-H1900 ASSY-TUBE BRAKE MASTER CYL FR(TANDEM)TO 2 46224-H3901 ASSY-TUBE,B/MASTER CYL. RR (TANDEM) TO 0573- 2 46224-H3900 2 46224-H1900 ASSY-TUBE BRAKE MASTER CYL RR(TANDEM)TO 2 46224-H1901 ASSY-TUBE BRAKE MASTER CYL. RR(TANDEM)TO OP 1170- 2 46224-H1900 2 46224-H3900 ASSY-TUBE,B/MASTER CYL.RR (TANDEM) TO 1071-0473 30 46224-H1901 3 46100-26100 ASSY-SWITCH BRAKE INDICATOR 3 46100-U5200 ASSY-SWITCH BRAKE INDICATOR 1071-0473 32 46100-26100 4 08360-63514 SCREW-MACHINE WITH WASHER 5 46240-H1900 ASSY-TUBE BRAKE FRONT RH FOR TANDEM B -473 3 5 46240-H1901 ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE 0573- 2 46240-H1900 5 46240-G1300 ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE 0573- 2 46240-H1901 6 46242-H1900 ASSY-TUBE BRAKE FRONT LH FOR TANDEM B -473 3 6 46242-H1901 ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE 0573- 2 46242-H1900 6 46242-G1300 ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE 0573- 2 46242-H1901 7 46280-H1902 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B MANUAL 0573- 2 46280-H1901 7 46280-H1905 ASSY-TUBE CONNECTOR TO REAR AUTOMATIC 7 46280-H1906 ASSY-TUBE CONNECTOR TO REAR AUTOMATIC 46280-H1905 7 46280-H1901 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B MANUAL -473 3 7 46280-H1902 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B MANUAL -473 3 46280-H1901 8 46313-18000 CONNECTOR-3WAY REAR 8 02463-13200 CONNECTOR-3WAY REAR 46313-18000 9 08110-82562 BOLT-HEX WITH WASHER M8 10 46290-H5501 ASSY-TUBE REAR BRAKE RH COUPE 0673- 5 46290-H1001 10 46290-H7301 ASSY-TUBE REAR BRAKE RH COUPE 0673- 5 46290-H5501 10 46290-H1000 ASSY-TUBE REAR BRAKE RH SEDAN COUPE -473 3 10 46290-H1001 ASSY-TUBE REAR BRAKE RH SEDAN COUPE 0573- 2 46290-H1000 10 46290-H5001 ASSY-TUBE REAR BRAKE RH SEDAN 0673-0473 35 46290-H1001 10 46290-H7201 ASSY-TUBE REAR BRAKE RH SEDAN 0673-0473 35 46290-H5001 11 46310-H5501 ASSY-TUBE REAR BRAKE LH COUPE 0673- 5 46310-H1001 11 46310-H5001 ASSY-TUBE REAR BRAKE LH SEDAN 0673-0672 25 46290-H1001 11 46310-H1000 ASSY-TUBE REAR BRAKE LH SEDAN COUPE -473 3 11 46310-H1001 ASSY-TUBE REAR BRAKE LH SEDAN COUPE 0573- 2 46310-H1000 12 46201-89918 ASSY-HOSE BRAKE REAR L=330 12 46201-H7200 ASSY-HOSE BRAKE REAR L=330 46201-89918 13 46237-18000 GASKET-BRAKE HOSE TO TUBE 14 46205-61000 PLATE-LOCK BRAKE HOSE 15 46206-18000 SPRING-LOCK BRAKE HOSE
