Part Numbers Index
From Datsun 1200 Club
Category: Catalog
This is an index of Nissan Part Numbers for Datsun 1200. Note that discontinued (NLA) parts from Nissan can sometimes be found on eBay or other sellers (NOS or "New Old Stock").
Engine
Engine ASSEMBLY
Engine Gasket Kit Repair Kit, Regrind Kit
Block & Pan CYLINDER BLOCK, FRONT COVER & OIL PAN
 * Timing Chain Cover, Cylinder Liner
Head CYLINDER HEAD, ROCKER COVER & THERMOSTAT
Emission Control
Piston, Crank & Rod PISTON, CRANKSHAFT & CONNECTING ROD
 * flywheel, flex plate, cam bearings
Valvetrain CAMSHAFT, VALVE, SPROCKET & CHAIN
Manifold intake (inlet) & exhaust
Twin Carb Manifold Part Numbers GX intake & GX exhaust
Oil Pump & OIL STRAINER (oil filter)
Water Pump & FAN
Fuel
Carburetor (CRANK) with Manual Choke
Carburetor (EXHAUST & EVAPO) with Manual Choke
DCH Carburetor with Auto Choke
GX Carburetor (TWIN)
Air Cleaner To May 1971
GX Air Cleaner
Fuel Pump
Fuel Piping & STRAINER
Chassis & Body
Engine Support
Exhaust & MUFFLER
Sedan Fuel Tank (SEDAN)
Sedan Fuel Tank (SEDAN EVAPO)
Coupe Fuel Tank (COUPE)
Coupe Fuel Tank (COUPE EVAPO)
Truck Fuel Tank
Engine Control ACCELERATOR PEDAL & CHOKE CONTROL
Radiator
Engine Mounting
Power Train
Clutch CLUTCH DISC, CLUTCH COVER & WITHDRAWAL LEVER
Hydraulic Clutch Pedal LHD
Clutch Pedal & clutch cable RHD
Clutch Cylinder MASTER
Clutch Cylinder OPERATING (slave)
Transmission Assembly
F5C56A Case
F4W56L Case & REAR EXTENSION & SPEEDOMETER PINION(4 SPEEED To March 1973)
F4W56A Case & REAR EXTENSION & SPEEDOMETER PINION(4 SPEEED From April 1973)
F4W56L Gear (4 SPEED) To March 1973
F4W56A Gear (4 SPEED) From April 1973
F4W56L Control & FORK & LEVER(4 SPEED) To March 1973
F4W56A Control & FORK & LEVER(4 SPEED) To From April 1973
Automatic Transmission Case & FITTING(AUTOMATIC 3N71B)
Automatic Transmission Gear (3N71B)
Automatic Transmission Hardware OIL PUMP, CLUTCH & BRAKE (3N71B)
Automatic Transmission Valve CONTROL VALVE (3N71B)
Propeller Shaft PROPELLER SHAFT (driveshaft/tailshaft)
Differential GEAR CARRIER & GEAR
Automatic Transmission Control FLOOR SHIFT TYPE
Axle
Front Axle FRONT AXLE, ROAD WHEEL & TIRE
Front Suspension FRONT SUSPENSION(STRUT, SHOCK ABSORBER)
Rear Axle REAR AXLE, ROAD WHEEL & TIRE
Rear Suspension REAR SUSPENSION(SPRING LEAF, SHOCK ABSORBER)
Brake
Hand Brake & HAND BRAKE CABLE
Front Drum Brake FRONT BRAKE(DRUM TYPE)
Disc Brake FRONT BRAKE(DISC TYPE)
Rear Brake & WHEEL CYLINDER(FOR FRONT DRUM BRAKE)
Rear Brake & WHEEL CYLINDER(FOR FRONT DISC BRAKE)
Brake Piping (TANDEM)
Brake Pedal
Tokico Brake Master Cylinder (TANDEM) To September 1971
Nabco Brake Master Cylinder (TANDEM) To September 1971
Tokico Brake Master Cylinder (TANDEM) From October 1971
Nabco Brake Master Cylinder (TANDEM) From October 1971
Steering
Steering Gear STEERING GEAR(COLLAPSIBLE) includes Steering Column
Steering Linkage STEERING LINKAGE
Steering Wheel STEERING WHEEL & STEERING LOCK
Electrical
Engine Electrical System
Distributor (CRANK)
Distributor (EXHAUST & EVAPO)
Spark HIGH TENSION CABLE, IGNITION COIL & SPARK PLUG
     * includes Alternator Mounting
Alternator & Regulator
ALTERNATOR(HITACHI)
Starter Motor
Body Electrical System
Wiring includes Wiring Harness
Switch & FLASHER UNIT, HORN & CIGARETTE LIGHTER
* Includes Electrical Unit, Instrument, Switch & Relay
Meter SPEEDOMETER, COMBINATION METER & FLEXIBLE SHAFT(ROUND)
 * includes instrument panel
 * includes temperature gauge sender (thermal transmitter)
Room Heater & Ventilator
Room Heater, Heavy Duty
Ventilator
Radio & Clock & ANTENNA
Battery (see Front Body Panels for Battery Mounting)
Wiper & Washer WINDSHIELD WIPER, MOTOR & WIPER BLADE
Wiper & Washer WINDSHIELD WASHER
Head Light HEAD LAMP
Front Combination Lamp
Side Lighting SIDE MARKER LAMP
Sedan Rear Combination Lamp
Coupe Rear Combination Lamp
License Lamp (SEDAN)
License Lamp (COUPE)
Room Lamp (Dome Light)
Body & Trim
Sedan
Grille RADIATOR GRILLE & FRONT BUMPER(SEDAN)
082 Front Body Panels FRONT FENDER, HOOD LEDGE, HOOD & DOOR MIRROR(SEDAN)
    * includes Radiator Core Support & front apron/valence
    * includes battery support frame/box
083 Hood Lock HOOD LOCK CONTROL(SEDAN)
084 Cowl COWL TOP & COWL TOP GRILLE(SEDAN)
085 Dash DASH PANEL, DASH SIDE PANEL & INSTRUMENT PANEL(SEDAN) includes package tray
086 Dash Trim GLOVE BOX & ASH TRAY(SEDAN)
087 Windshield WINDSHIELD GLASS, WEATHERSTRIP & MOULDING(SEDAN)
088 Roof ROOF PANEL, SUNVISOR & INSIDE BACK MIRROR(SEDAN)
089 Floor FLOOR PANEL, INSULATOR & SPARE WHEEL HANDLE(SEDAN)
090 Floor Trim FLOOR MAT, KICKING PLATE & CONSOLE BOX(SEDAN) includes carpet
091 Body Side BODY SIDE PANEL & REAR WHEEL HOUSE(SEDAN 2 DOOR)
092 Body Side Trim BODY SIDE FITTING & MOULDING(SEDAN)
093 Interior Side Trim BODY SIDE TRIMMING(SEDAN) includes ash tray & weatherstripping
094 Rear Body REAR FENDER & REAR PANEL(SEDAN) includes parcel tray & fuel door
095 Rear Window SIDE WINDOW & REAR WINDOW(SEDAN)
096 Front Door FRONT DOOR PANEL, GLASS & DOOR VENTILATOR(SEDAN 2 DOOR)
097 Front Door Fitting FRONT DOOR LOCK, REGULATOR & DOOR HANDLE(SEDAN 2 DOOR)
098 Front Door Trim FRONT DOOR MOULDING, FINISH & ARM REST(SEDAN 2 DOOR)
105 Trunk & Bumper TRUNK & REAR BUMPER(SEDAN) (boot)
106 Front Seat FRONT SEAT(SEDAN)
107 Rear Seat REAR SEAT(SEDAN)
108 Seat Accessories SAFETY BELT & HAND REST(SEDAN)
Coupe
GROUP 08 BODY (COUPE)
111 Grille RADIATOR GRILLE & FRONT BUMPER(COUPE)
112 Front Body Panels FRONT FENDER, HOOD LEDGE, HOOD & DOOR MIRROR(COUPE)
113 Hood Lock HOOD LOCK CONTROL(COUPE)
114 Cowl COWL TOP & COWL TOP GRILLE(COUPE)
115 Dash DASH PANEL, DASH SIDE PANEL & INSTRUMENT PANEL(COUPE) includes Package Tray
116 Dash Trim GLOVE BOX & ASH TRAY(COUPE)
117 Windshield WINDSHIELD GLASS, WEATHERSTRIP & MOULDING(COUPE)
118 Roof ROOF PANEL, SUNVISOR & INSIDE BACK MIRROR(COUPE)
119 Floor FLOOR PANEL & FITTING(COUPE)
120 Floor Trim FLOOR MAT, CARPET, KICKING PLATE & CONSOLE BOX(COUPE)
121 Body Side BODY SIDE PANEL & REAR WHEEL HOUSE(COUPE)
122 Body Side Trim BODY SIDE FITTING & MOULDING(COUPE)
123 Interior Side Trim BODY SIDE TRIMMING(COUPE) includes ash tray & weatherstripping
124 Rear Body REAR FENDER & REAR PANEL(COUPE) includes parcel tray & fuel door
125 Rear Window SIDE WINDOW(COUPE)
126 Front Door FRONT DOOR PANEL, GLASS & DOOR VENTILATOR(COUPE)
127 Front Door Fitting FRONT DOOR LOCK, REGULATOR & DOOR HANDLE(COUPE)
128 Front Door Trim FRONT DOOR MOULDING, FINISH & ARM REST(COUPE)
129 Rear Window REAR WINDOW(COUPE)
130 Trunk & Bumper TRUNK LID & REAR BUMPER(COUPE) (boot)
131 Trunk Fitting TRUNK ROOM TRIMMING(COUPE) (boot)
132 Front Seat FRONT SEAT(COUPE)
133 Rear Seat REAR SEAT & TONNEAU COVER(COUPE)
134 Seat Accessories SAFETY BELT & HEAD REST(COUPE)
Wagon
Back Door Part Numbers
Truck
101 Front View includes RADIATOR GRILLE, FRONT BUMPER, COWL TOP GRILLE and mirrors
 Radiator Grille
 Front Bumper
 Cowl Cowl top, grille and seals
 Wing Mirror
102 Hood Ledge & Dash Fitting
 882 Hood Ledge Part Numbers HOOD LEDGE
 882 Dash Fitting Part Numbers DASH FITTING
103 Hood Hinge & Lock
 Hood Hinge
 Hood Lock Control
104 Front Window includes trimming
 Windshield
 Rear-view (Inside) Mirror
 Sunvisor
105 Instrument Includes dash PAD, trim, GLOVE BOX & ASH TRAY
 * & PACKAGE TRAY, FLARE HOLDER
106 Floor Trimming
 Dash Trimming
 Floor Trimming
107 Floor Fitting
 Front Floor Fitting
 Console Box
108 Dash Side Trimming
 Dash Side Trimming
 Body Side Trimming
 Roof Trimming
109 Door
 Door 109a
 Door Hinge
 Door Fitting 109b
 Door Trimming
 Side Visor
110 Door Window & Lock
 Door Window
 Door Lock & Remote Control
 Door Handle & Regulator
111 Seat フロント シート <トリム>
 Seat
 Head Restraint
 Safety Seat Belt
112 Body Side Fitting
 Side Moulding includes side vent
 Fuel Filler Door
 Rear Bumper
 Back Window
 Rear Gate Fitting
 Rear Floor Fitting
113 Front Body Panel 812
 Radiator Core & Apron Panel
 Front Fender Panel
 Hood Ledge & Hood Panel
114 Dash Panel
 Dash Panel
 Front Floor Panel
 Front Pillar Panel
 Roof Panel
 Back Lower Panel
115 Rear Body Panel (Short Body)
116 Rear Body Panel (Long Body) includes Center Bearing Bracket
 Rear Body Side Panel
 Rear Floor Panel 840 フロア パネル
 Back Panel
 Rear Gate Panel
117 Key Set
Label
Miscellaneous
GROUP 09
167  Emblem (Badge/Mark)
168  Key & Cylinder
169  Key & Cylinder BLANK KEY
170  Model Plate MODEL NO. PLATE  プレート、モデル ナンバー
171  Paint TOUCH-UP PAINT
172  Coolant LONG LIFE COOLANT & N.C.S. SEALER
173  Tool Kit includes Jack
173A Special Tool
175  Leather Top (Vinyl Roof)
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Part_Numbers_Index"
This page has been accessed 29,326 times. This page was last modified 04:34, 21 April 2013. Content is available under Datsun 1200 Club.
