Also see:
Part Numbers Index Main article for usage, photos, cross-reference Automatic Shifter
1 34902-H1900 ASSY-HAND LEVER & BRACKET AUTOMATIC 2 34903-H1900 ASSY-BRACKET HAND LEVER AUTOMATIC 3 34907-25820 BUSH-HAND LEVER BRACKET (2) AUTOMATIC 4 34909-H1100 PACKING-HAND LEVER BRACKET AUTOMATIC 5 34915-H1100 ASSY-SUPPORT HAND LEVER AUTOMATIC 6 34946-H0300 SPRING-RETURN SELECT AUTOMATIC 7 34912-H1100 LEVER-HAND AUTOMATIC 8 34919-25820 KNOB-HAND LEVER AUTOMATIC 8 34919-H1000 KNOB-HAND LEVER AUTOMATIC 1171- 2 34919-25820 9 34923-25820 SCREW-HAND LEVER AUTOMATIC 10 34947-25820 PIN-SELECT AUTOMATIC 11 18136-61503 RING-SNAP"E" (2) AUTOMATIC 12 34913-H1900 ASSY-SHAFT HAND LEVER AUTOMATIC 13 34434-89900 SCREW-LOCK AUTOMATIC 14 00851-21610 WIRE-LOCK AUTOMATIC 15 08360-82014 SCREW-MACHINE M8X1.25 (4) AUTOMATIC 16 34932-H2520 COMP-SHAFT ROD AUTOMATIC 17 34552-89900 INSULATOR-ROD (2) AUTOMATIC 18 34419-04100 WASHER-SPRING (2) AUTOMATIC 19 34485-14805 PIN-SPRING (2) AUTOMATIC 20 34951-H2520 ASSY-CROSS SHAFT AUTOMATIC 21 34952-H1100 COMP-BRACKET CROSS SHAFT AUTOMATIC 22 34462-18000 BUSH-SPHERICAL CROSS SHAFT (2) AUTOMATIC 23 34965-25820 COVER-OUTER RH CROSS SHAFT AUTOMATIC 24 34966-25820 COVER-INNER RH CROSS SHAFT AUTOMATIC 25 34463-14806 SPRING-RETURN CROSS SHAFT AUTOMATIC 26 34467-84700 BOOT-OUTER CROSS SHAFT AUTOMATIC 27 74941-89900 COVER-OUTER LH CROSS SHAFT AUTOMATIC 28 34936-H1100 COMP-SHAFT ROD LOWER AUTOMATIC 29 34938-25820 PIN-SHAFT ROD AUTOMATIC 30 34948-25820 RING-SNAP 'E' TYPE AUTOMATIC 31 34410-21000 TRUNION-GEAR SHAFT ROD AUTOMATIC 32 34552-89900 INSULATOR-ROD AUTOMATIC 33 01311-00021 WASHER-PLAIN (2) AUTOMATIC 34 34419-04100 WASHER-SPRING AUTOMATIC 35 34485-14805 PIN-SPRING AUTOMATIC 36 08911-14010 NUT-HEX M10X1.25 (2) AUTOMATIC
