Steering Wheel Part Numbers
Revision as of 08:20, 8 July 2017; view current revision
Categories: Steering System | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Steering Wheel
1 48400-H1101 ASSY-WHEEL STEERING EXC OKINAWA
1 48400-H6101 ASSY-WHEEL STEERING 48400-H1101
2 48429-H1010 ASSY-RING SLIP OP SEDAN COUPE
3 48422-H1110 ASSY-PAD WHEEL EXC OKINAWA
4 48432-H1010 BUTTON-HORN(L)
5 48432-H1011 BUTTON-HORN(P)
6 48424-H1010 SPRING-HORN (2)
7 48464-H1010 RING-INSULATOR (2)
8 48498-H1100 EMBLEM 'D' MARK EXC OKINAWA
9 48435-H1010 GUIDE-HORN BUTTON (2)
10 08911-34210 NUT-HEX 12
11 08916-24210 WASHER-TOOTH 12
12 48471-H1950 SET-SHELL STEERING WITHOUT PARK LIGHT S 4 SPEED 48471-H1650
12 48470-H4650 SET-SHELL STEERING WITHOUT PARK LIGHT S EXC OKINAWA 0172- 2 48471-H1950
12 48471-H1650 SET-SHELL STEERING 4 SPEED AUTO.
13 08530-42012 SCREW-TAPPING M4 (3)
14 08330-41410 SCREW-MACHINE M4
15 48700-H1900 ASSY-LOCK STEERING
15 48700-H1901 ASSY-LOCK,STEERING(5 POINT) 0471- 0 48700-H1900
16 48750-H1900 ASSY-SWITCH IGNITION
16 48750-E7705 ASSY-SWITCH IGNITION (5 POINT) 0471- 0 48750-H1900
17 48760-H1900 SWITCH-WARNING DOOR BUZZER
17 48700-H1900 SWITCH-WARNING DOOR BUZZER 2 48760-H1900
18 24814-H1900 ASSY-BUZZER DOOR CHECK
18 24814-H1901 ASSY-BUZZER DOOR CHECK 4 24814-H1900
18 24814-H1902 ASSY-BUZZER,DOOR CHECK 0370- 2 24814-H1901
19 48780-H1900 BRACKET-BUZZER
20 08510-51012 SCREW TO FIX BUZZER TO BRACKET (2)
