Tokico Brake Master Cylinder Part Numbers
Revision as of 08:11, 8 July 2017; view current revision
Categories: Brake System | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Brake master cylinder
To September 1971
TBD
From October 1971
1 46010-H3300 ASSY-CYLINDER,BRAKE MASTER (TANDEM)FOR 1071-
1 46010-H3100 ASSY-CYLINDER,BRAKE MASTER (TANDEM) FOR 1071-
2 46073-B5010 ASSY-PISTON,SECONDARY FOR DRUM
2 46073-H3310 ASSY-PISTON,SECONDORY FOR DISC
3 46064-B5010 CUP-PISTON (2)
4 46066-B5010 SPACER-CUP
5 46068-B5010 CUP-PISTON
6 46062-B5010 SEAT-SPRING
7 46075-B5010 SPRING-RETURN
8 46063-H3310 ASSY-PISTON PRIMARY
9 46064-B5010 CUP-PISTON
10 46066-B5010 SPACER-CUP
11 46068-B5010 CUP-PISTON
12 46062-B5010 SEAT-SPRING
13 46065-B5010 SPRING-RETURN
14 46070-27260 RING-PISTON,STOPPER
15 46079-R1200 GASKET-PISTON STOPPER
16 46032-R1200 STOPPER-SECONDARY PISTON
17 46027-A6900 SPRING-RESIDUAL VALVE (2)
18 46050-H0111 ASSY-VALVE,RESIDUAL FOR DRUM (2)
18 46050-H0111 ASSY-VALVE,RESIDUAL FOR DISC
19 46057-10610 RETAINER-VALVE FOR DRUM (2)
19 46057-10610 RETAINER-VALVE FOR DISC
20 46050-73410 ASSY-VALVE,RESIDUAL FOR DISC
21 46057-73410 RETAINER-VALVE FOR DISC
22 46042-27260 PACKING-VALVE (2)
23 46038-21011 PLUG-CYLINDER (2)
24 46090-U0512 PESERVOIR-OIL FOR DRUM (2)
24 46090-U0512 RESERVOIR-OIL FOR DISC
25 46091-U0512 RESERVOIR-OIL FOR DISC
26 46016-10610 BAND-RESERVOIR (2)
27 46093-N0410 FILTER-OIL (2)
28 46020-U0512 ASSY-CAP,OIL RESERVOIR (2)
28 46020-K2411 ASSY-CAP,OIL RESERVOIR (2) 46020-U0512
29 41128-U0512 SCREW-BLEEDER (2)
30 41129-A2410 CAP-BLEEDER (2)
30 41129-40F00 CAP-BLEEDER (2) 41129-A2410
31 46100-27260 COVER-DUST
32 46080-H3110 ASSY-ROD,PUSH
33 46010-H3125 KIT-REPAIR,BRAKE MASTER CYL.
34 46010-H3325 KIT-REPAIR,BRAKE MASTER CYL.
