Datsun 1200 axle shafts come in two sizes: H145 for all cars, and H165 units for all 1200 Trucks. Both are 23-spline axles, although the truck axles are a larger diameter and so they do not interchange.
Bearing Replacement
The bearing is held on a by a collar (a plain ring). This has to cut off with a cold chisel, then a new one pressed on.
Bearing held on by shaft collar
When replacing a rear axle bearing, check the wheel bearing-to-housing end face clearance and adjust with shims.
Wheel Bearing Packing
Axle Seal
Suppliers - USA
- Nissan
- RockAuto differential parts
- http://www.partsamerica.com
Axle
- 38162-G0300 ASSY-SHAFT REAR AXLE B110, B210
- 38162-H8500 SHAFT ASSY-REAR AXLE(L=612) B310
- 38162-G1000 SHAFT ASSY-REAR AXLE B120 7510- with H165 diff
- Also B210 H165B with L16 engine
Axle Seal
Datsun 1200 uses the same rear axle/wheel hub seal as Datsun 510. One is required for each side of the car. The same seal is used by H145 (1200 car) and H165 (1200 truck) rear axle assemblies.
Nissan 43252-H1000 SEAL-OIL REAR AXLE SHAFT * formerly 43252-18000 * alternate manufacturer: 43252-H1010
Aftermarket SKF OS550232 Timkin 1181 BECK/ARNLEY 0521583 (052-1583) size 41x58x4 * FITS many Nissan/Datsun including: * 1200 sedan/coupe/wagon/truck * Datsun B10 Datsun 1000 * Datsun 510/610 * Datsun S10 200SX 1977-1979 * Datsun A10 1978-1981 (Stanza/510/Violet) * Nissan D21,D21U,D22 Nissan pickups 1986-2000 some * Nissan R50 "Pathfinder" rear outer "Grease Hub Seal" * Nissan WD21,WD22 "Pathfinder" 43252-0W000 * Nissan/Datsun 810/910 wagon (810/Maxima/Bluebird) * S110 1984 200SX w/CA20E engine SELECT USE
Timkin 1811 interchange Beck/Arnley 0523605 Beck/Arnley W72173 Beck/Arnley W72231 Nation 1181 GM 12305324/15527580 ITM 1501004 Bap-Geon 1530501/1530505 SKF 16496 SKF 550232 Vera 6501018 Vera 6601000 Victor 66545 Victor 66984 Intlps 775532 Acura 91212P5G004 Acura 91212PH7013 Acura 91212PY3003 Honda 91212PH7003 Honda 91212PH7013 Honda 91212PR7A01 Honda 91212PY2003 Honda 91212PY3003 L&S/TROSTL A45556S Guran/Midas GS1386 Nissan 40232-M0200 Victor JV1054 IAPCO L0020012 Lazorlite L816671 Lazorlite L817376 Payen NJ036 Payen NJ120 Payen NK023 Repco P6374 Repco PR6374 Repco 2116374
Axle Bearing
H145
- Nissan 43255-H1000 COLLAR-REAR AXLE BEARING
- Required when replacing the bearing. The collar is cut in two to release the bearing, and the new collar pressed on.
- Nissan 43215-18000 BEARING-REAR AXLE
- SKF GRW115R Schuck's
- KOYO 83294C4
- NSK B32-3CC5
- NTN 6206BLUX/32C4 $28 USD
Interchange:
- 1967-1970 Datsun B10 (180 is B10 part number)
- 1970-1973 Datsun B110
Specs:
- O.D.: 62.000 (mm)
- Bore: 30.000 (mm)
- ?? 32 mm
- Width: 16.000 (mm)
H150/H165
- 43215-H5000 BEARING-REAR AXLE, OUTER B120 7510-, B210 H150
