Mildman
In this own words:
Before I could begin installing the engine into the 1200 engine bay I want to change over the crossmember. I had a standard 1200 coupe crossmember that has each tower the same length. To fit an A14/15 onto this crossmember requires some modification. I got lazy and bought a crossmember from a post 1974 1200 ute which mounts up to the later A12 with the dizzy in the middle. This is the same configuration as the A14,15. I talked a bit about this crossmember in the last A14 prep pages too.
So change over crossmember. Jack it up put it on jack stands and loosen off lower control arms
