The wiper motor bolts to the engine compartment firewall. LHD cars sweep to the left, RHD sweeps to the right. For the windscreen washer, see Kangaroo Bag.
Wiper Motor
As with the rest of the wiper system, Wiper Motor for RHD and LHD are reversed. RHD models have the wiper motor on left side, just below the left bonnet hinge.
See main article: Wiper Motor
Wiper Switch
See Wiper Switch
Wiper Arms
The arms are the part outside the windshield, minus the blade.
RHD
- 26380-H1000 ARM ASS'Y-wiper ALL (except GX)
- 26380-H2300 ARM ASS'Y-wiper GX
LHD
26380-H1600 ASSY-ARM WIPER
ID marks:
* upper: '56L' underneath by spring
* lower: 'AE' mark on top, visible when installed
Wiper Arm Comparo: B110 vs B210 (Left-hand drive)
Wiper Blades
The blade is the part that holds the rubber inserts (refills).
To separate arm from blade, insert knife as shown to lift up tab. Then pull the blade off the arm.
Datsun 1200 uses 16" (405mm) wiper blades. The original blade was a stainless steel design marked "56L" on the bottom and "AE" on top. This blade takes 5/16" wide refills (9mm).
GX-5 option: For high-speed stability, it has a built-in wind spoiler
Refills
For stock wiper arms, the refills are 16" long x 5/16" "Universal" style.
NOTE: over the years many 1200 blades have been replaced quick-replacment types, so your 1200 may have something else.
- NAPA 762-3164
- Package say "Standard" type
- TRICO 44160
- 44 Series Universal wiper refills are designed to fit most long frame TRICO, Tridon, Roberk, Anco, Pylon and Original Equipment plastic blades. Designed with metal end clips for ease of installation.
RHD
- 26360-H1000 BLADE ASS'Y-wiper ALL (except GX)
- 26360-H2300 BLADE ASS'Y-wiper GX
- 26370-A4600/A4601 BLADE ASS'Y-wiper GX-5, Optional ALL (same as Datsun 510 SSS/CSS blades)
- B6370-89901 OLD Type L=400 Black
LHD
- 26375-U5200 ASSY-BLADE WIPER [Option, High Speed]
- replaces 26375-A4601 ASSY-BLADE WIPER OP
- replaces 26375-A4600
- 26360-B5200 ASSY-BLADE WIPER [non-High Speed] B210
- 26375-H7700 ASSY-BLADE WIPER [Matte Black, 1978) B210
Linkage
See main article: Wiper Wiring
Seals
28876-H1000 SEAL-PIVOT WINDSHIELD WIPER 2 $2.43 USD
ワイパー
