Side Lighting Parts Numbers
Revision as of 08:32, 8 July 2017; view current revision
Categories: Catalog | Body Electrical System
<-- back to Part Numbers Index
Also see:
Main article for usage, photos, cross-reference:
Side Lamps
SIDE FLASHER LAMP
13 26160-H1001 LAMP ASS'Y-side flasher -7803 2
   26160-G1060 LAMP ASSY-SIDE FLASHER 7804- 2
14 26161-H1001 LENS 2
15 26162-H1001 RIM-LENS 2
16 26164-H1001 PACKING -7803 2
   26164-G1060 PACKING 7804- 2
17 01451-00071 SCREW 4
18 08964-10410 NUT-spring 4
19 26715-89900 BULB (12V-6W) 2
SIDE MARKER LAMPS
1 26180-H1900 ASSY-LAMP SIDE MARKER FRONT RH (ICHIKHO)
1 26180-H7000 ASSY-LAMP SIDE MARKER FRONT RH OKINAWA 0772- 2 26180-H1900
2 26185-H7000 ASSY-LAMP SIDE MARKER FRONT LH OKINAWA 0772- 2 26185-H1900
2 26185-H1900 ASSY-LAMP SIDE MARKER FRONT LH(ICHIKHO)
3 26181-H1900 LENS(ICHIKHO) 2
4 26182-H1900 RIM(ICHIKHO) 2
5 26184-H1900 PACKING RH(ICHIKHO) 2
6 26189-H1900 PACKING LH(ICHIKHO) 2
7 01451-00041 SCREW(ICHIKHO) 4
8 08964-10410 NUT-SPRING(ICHIKHO) 4
9 26715-89902 BULB 12V-8W(ICHIKHO) 2
10 26190-H1910 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) COUPE
10 26190-H1900 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) SEDAN
11 26195-H1900 ASSY-LAMP SIDE MARKER REAR LH(ICHIKHO) SEDAN
11 26195-H1910 ASSY-LAMP SIDE MARKER REAR LH(ICHIKHO) COUPE
12 26191-H1900 LENS(ICHIKHO) 2
13 26182-H1900 RIM(ICHIKHO) 2
14 26194-H1900 PACKING RH(ICHIKHO) SEDAN
14 26194-H1910 PACKING RH(ICHIKHO) COUPE
15 26199-H1900 PACKING LH(ICHIKHO) SEDAN
15 26199-H1910 PACKING LH(ICHIKHO) COUPE
16 01451-00061 SCREW(ICHIKHO) 4 COUPE
16 01451-00041 SCREW(ICHIKHO) 4 SEDAN
17 08964-10410 NUT-SPRING(ICHIKHO) 4
18 26715-89902 BULB 12V-8W(ICHIKHO) 2
