Single Brake Master Cylinder Part Numbers
Revision as of 08:10, 8 July 2017; view current revision
Categories: Brake System | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Brake master cylinder
For all-drum models (Standard trim, plus Deluxe Van).
To September 1971
SINGLE BRAKE MASTER CYLINDER (up to '71-Sept.) Std., V-dx.
46010-18001 ASS'Y-CYLINDER, brake master (single) <> 46010-H1010
46010-H1010 ASS'Y-CYLINDER, brake master (from '70-Oct.)
  1 46016-10610 ASS'Y-BAND, reservoir (TOKICO)
    46016-12200 ASS'Y-BAND, reservoir (NABCO)
  2 46020-10611 ASS'Y-CAP, reservoir (TOKICO)
    46020-E0300 ASS'Y-CAP, reservoir (NABCO)
  3 46063-18010 ASS'Y-PISTON, brake master (TOKICO)
    46063-18000 ASS'Y-PISTON, brake master (NABCO)
  4 46068-18010 CUP-piston (S) (TOKICO)
    46068-18000 CUP-piston (S) (NABCO)
  5 46070-27260 RING-stopper
  6 46073-18010 VALVE (TOKICO)
    46050-18000 ASS'Y-VALVE (NABCO)
  7 46074-18010 SEAT (TOKICO)
    46057-18000 SEAT-valve (NABCO)
  8 46075-18010 SPRING-return (TOKICO) <> 46075-18011
    46075-18011 SPRING-return (TOKICO)
    46075-18000 SPRING-return (NABCO)
  9 46076-18010 SEAT-spring (TOKICO)
    46076-18000 SEAT-spring (NABCO)
  10 46078-18010 CUP-piston (P) (TOKICO)
     46078-18000 CUP-piston (P) (NABCO)
  11 46081-18010 ASS'Y-ROD, push (TOKICO)
     46080-18000 ASS'Y-ROD, push (NABCO)
  12 46091-10610 RESERVOIR-brake oil (TOKICO)
     46091-18000 RESERVOIR-brake oil (NABCO)
  13 46100-27260 COVER-dust
14 46093-N0110 FILTER (TOKICO)
   46093-N0100 FILTER (NABCO)
fixing brake master cylinder
  15 30614-18000 BOLT (2) <> 30614-21002
     30614-21002 BOLT (2)
  16 89-15138-1 WASHER-lock (2)
  17 89-11108-1 NUT (2)
18 46123-08700 PIN-clovis
46010-18025 KIT-REPAIR, brake master cylinder "A" (TOKICO)
46010-18027 KIT-REPAIR, brake master cylinder "A" (NABCO)
46010-18026 KIT-REPAIR, brake master cylinder "B" (TOKICO)
46010-18028 KIT-REPAIR, brake master cylinder "B" (NABCO)
as required
  46117-27260 SHIM-master cylinder (1.6 t)
  46118-27260 SHIM-master cylinder (0.8 t)
  46119-27260 SHIM-master cylinder (0.5 t)
From October 1971
SINGLE BRAKE MASTER CYLINDER (from '71-Oct.) Std., V-Dx.
46010-H3600 ASS'Y-CYLINDER, brake master (single)
