Also see Lighting System
1. Exterior single element, one bottom contact
Rear T/S (turn signal)
* 23 watt Sylvania 1156 Wagner 1156 * North America * Japan * 21 watt (other countries)
2. Exterior dual element, two bottom contacts
Front park & T/S, Rear Tail & Stop
* 23/8 watt (North America) Sylvania 1157 Wagner 1157 * 12/5 watt (other countries)
3. 10-AMP FUSE
(2 needed) 08941-11000 for Fuse Box
4. 15-AMP FUSE
(4 needed) 08941-11500 for Fuse Box
5. Seat Belt Lamp
USA 1972-1973 Seat belt light (on top of dash) Toshiba 12V 10W Type SV8.5 31mm long
* 26945-H4600 (not sure if this lamp only, or whole unit) Sylvania DE3175 Wagner 12100
6. Dome Lamp
10 watt (room lamp) 26736-89902 * Type SV7, ~29 mm long (pictured) seems to fit best, but are usually 3w or 5w * Some parts stores specify the larger unit (see above Wagner 12100, Sylvania DE3175) which is readily available
7. Instrument Panel Lamp
Twist-lock holder (7 used in round dash).
26260-89900 Wedge Socket (7 total) $3.28 USD each
These sockets fit bulbs with a W2.1x9.5d base (aka W2, miniature wedge, or T5 base. Possibly also be called W5W base).
T10 bulbs come in different wattage and socket bases, the 1200 ones use a W2.1x9.5d base, known in USA as "Miniature Wedge".
USA * 26261-89902 1.7 watt bulb (ROUND GAUGE) 2.7 watt Type 161 is often specified by aftermarket JPN B110 * 26261-89900 BULB-12V, 1.5W SQUARE METER 7 * 26261-89902 BULB-12V, 1.7W ROUND METER 7 JPN B120 * 26261-89900 7510-7803 12V-3.4W 商B113 8 3.4 watt Type 158 * 26261-89902 7804- 12V-2.7W 商B113 6 * 26711-89900 7804- 12V-1.7W 商B113 2 * 26711-89902 8910- 12V-2.7W 商B113 6 * 26711-89900 8910- 12V-1.7W 商B113 2
T10 glass with T5/W5W base * Type 194 1.0 watt * Type 161 2.7 watt
NOTE: Type 159 is identical looking, but only 1.0 watt 6.3V. In addition there are several others including lower and higher wattage versions.
8. Exterior Lamp
Side-marker lamp
* 8 watt (North America, non-flashing) Wagner 97 Sylvania 97 (9.32 watt nominal) * 6 watt (flashing, non-North America)
License lamp Sylvania 1895 Wagner 1895 (3.78 watt)
* 10 watt (Sedan, except North America) * 7.5 watt Coupe, Van 26715-89901 Ichikho * 7.5 watt Sedan USA Bailey B29.012.625 (7.5w) or [Toshiba A12V8W 6 7]
Reverse light - 10 watt
9. Instrument Panel Turn Signal
Indicators (2 needed)
* 26260-H1800 SOCKET-WITH LEAD WIRE BA9S/W6W socket
BULBS - G14 glass with BA9S/W6W base * 26711-89900 BULB 1.7 watt (ROUND GAUGE) can use 1.9 watt Type 1445 Wagner 1445 * 26261-89900 3.4 watt (Square Gauge) Type 57
Lamp Specifications
Head Lamp 26705-04101 Sealed beam unit (Koito) or 26705-08700 Sealed beam unit (Koito)
Front Combination Lamp - Early 26717-89920 BULB (12V-23/7W) 26261-89900 BULB (12V-3W)
Front Combination Lamp - Late 26717-89900 BULB (12V-23) [P21W] 26261-89920 BULB (12V-8/3.4W) [P21/5W???] * or 26261-89925 BULB (12V-8/3.4W) 7804-
North America
Spec. | SAE No. | Nissan^ | |
Headlight unit | 12V-50/40W | 6012 | 26705-04201 |
Direction and Parking | 12V-23/8W | 1034/[*1157] | 26717-89920 |
Side marker | 12V-8W | 67 | 26715-89902 |
License plate | 12V-7.5W | 89 | 26715-89901 |
Rear combo. Light Taillight Stop (brake) Turn signal Back-up light | 12V-23/8W 12V-23/8W 12V-23W 12V-23W | 1034 1034 1073/[**1156] 1073 | 26717-89920 26717-89900 |
Meter illumination | 12V-1.7W (round gauge) | 161 | 26711-89900 |
Wiper Knob illumination (1973) | 12V-3.4W | 158 | ? |
Heater control ill. (1973) | 12V-3.4W | 57 | ? |
Ignition warning | 12V-1.7W | 161 | 26711-89900 |
Turn Signal indicator | 12V-1.7W | 161 | 26261-89902 |
Headlight beam ind. | 12V-1.7W | 161 | 26711-89900 |
Oil press. warning | 12V-1.7W | 161 | 26711-89900 |
Brake warning | 12V-1.7W | 161 | 26711-89900 |
Room light | 12V-10W | n/a | 26736-89902 |
* 1157 can replace 1034 but uses more current ** 1156 can replace type 1073
USA 1972 Owners manual (see page 36 for bulb specifications):
Portugal
Opticas 12V-50/40W 12V-21/5W Luz de mudança de direcção o de presença 12V-6W Luzes laterais de mudança de direcção 12V-7.5W Luz da chapa de matricula
Conjunto de luzes traseiras 12V-5W luz de presença 12V-21W luz de stop (travões) 12V-21W luz de mudança de direcção 12V-21W luz de marcha atrás
12V-3W Luz de iluminacão do painel de instrumentos 12V-3W Luz avisadora da ignicão 12V-3W Luz indicadora dos máximos 12V-3W Luz avisadora da pressao do óleo 12V-10W Luz interior 12V-3W Luz de iluminação do relogió
