FIA
Revision as of 22:42, 15 May 2015; view current revision
Categories: Documentation | Racing
The Fédération Internationale de l'Automobile (FIA) is a governing body for racing rules. Datsun 1200 Group 1 FIA recognition includes twin-carb engine, rear spoiler, and 5-speed transmission.
B110
PDF Pages 1-14
FIA listing: July 1970 (14 pages)
Manufacturing started Nov 1969
* Car with no interior heating
* Wheelbase  2300 mm 90.55 in
* f track    1240 mm 48.82 in
* r track    1245 mm 49.02 in
* length     383 cm
* width      149.5 cm
* height     139.0 cm
* fuel tank  10.6 Gallon US
* Weight     635 kg (1399 lbs) with normal equipment, water, oil
             and spare wheel but without fuel no repair tools.
* Jack point ground clearance 160 mm
* f seat weight 10 kg each
* f bumper   3.0 kg
* r bumper   3.7 kg
* wheels     12 in x 4 in weight: 4.2 kg
* steering   3.3 turns
Engine
* hp             68ps JIS @ 6,000 rpm
* max rpm        6,400 rpm (64 ps)
* max torque     9.7 kg-m at 3,600 rpm
* max speed car  150 km/hour
* comb chamber   36.6 cm3
* flywheel weight 9.5 kg
* Flywheel with all turning parts 13.1 kg
Camshaft
* valves      29 mm 1.14 in
* max lift    9 mm 0.35 in
* opens       BBDC 56 degrees +- 7 degrees
* closes      ATDC 12 degrees +- 7 degrees
* exhaust ports 26w x 28h with 3 mm radius +- 1.5 mm
* center ex port 69w x 28h
* intake ports 28/27 mm circle
Carburetion
* Carb Hitachi DCG306-1 down-draft
* Primary: 26 mm, Secondary: 30mm
PDF page 10
Added Coupe and 4-dr sedan
* weight    640 kg 1411 lbs
A12GX engine
PDF pages 21-24
Amendment March 1970 (4 pages)
Engine
* compression ration   10.0
* combustion chamber   29.1 cm3
* valve opens       BTDC 20 degrees +- 7 degrees
* valve closes      ABDC 56 degrees +- 7 degrees
* valve opens       BBDC 58 degrees +- 7 degrees
* valve closes      ATDC 18 degrees +- 7 degrees
* Carb Hitachi HJE38W side-draft (two carbs)
* exhaust ports 27w x 29h +- 1.5 mm
* intake ports 30mm x 39mm oval
* hp             83ps @ 6,400 rpm
* max rpm        6,800 rpm (80 ps)
* max torque     10.0 kg-m at 4,400 rpm
* max speed car  160 km/hour
Overfender Flares
PDF pages 15-16
Amendment June 1970 (2 pages)
Wheel Spacer
PDF page 17
February 1971 Amendment (1 page)
Optional Part
Wheel spacer (5 mm)
Part Number 40209-A0220
Coupe Spoiler
PDF page 18
Not Valid For Group 1 Only
1972 Facelift
PDF pages 19-20
December 1971 Amendment (2 pages)
Cover the Facelift changess
