The speedometer reading is adjustable via the various drive gears fitted at the transmission. Depending on which final gear ratio (differential gears) are fitted, the speedometer gears are changed to keep the speedometer accurate.
Fast Search Slow Search
Google Ad |
![]() Speedometer GearsRevision as of 07:56, 12 October 2015; view current revision Printable version | Disclaimers | Privacy policy | Current revision The speedometer reading is adjustable via the various drive gears fitted at the transmission. Depending on which final gear ratio (differential gears) are fitted, the speedometer gears are changed to keep the speedometer accurate. |
