CR Engine Swap
Revision as of 10:00, 16 June 2015; view current revision
Category: Engine Swaps
Nissan CR engine is an all-alloy 16-valve engine -- the modern A-series, with same displacements and general engine dimensions. CR14DE is the most powerful.
CR10DE 1.0 liter
CR12DE 1.2 liter
CR14DE 1.4 liter with VVL, 98 hp
CR14DE is found in the 2002-2008 Nissan Z11 (2nd gen Nissan Cube) and in the 2003-2010 K12 (Nissan Micra/March).
You can buy a CR14DE for as little as $550 as a low KM motor from almost any Jap wrecker
24% more power than a stock A14
60kg lighter than A14
Appears to have same transmission bell pattern as E-series.
Potential for 300 hp with turbocharging
Challenges
* Starter mounting
* Sump fitting
The block has a huge crank girdle, which is great for strength, but mean it won't fit a standard crossmember. Solution: build a new crossmember that dips down.
The A-series gearbox starter location is right where a big CR engine boss is.
Revhead Mockup
Discussion: Is a CR14DE a viable conversion? Let's find out.
Revhead did some work on fitting it to a Datsun 1000.
Summary: Yes. The CR14DE is a viable conversion. There are some things that will need sorting out ... need sump modifications
61 - Sits a bit close to the firewall for the water outlet at the rear.
th_1B8AC149A5D3B55607FC3A3AFE8927F1.jpg th_2B16D9799005C44B8FB5ED6108B6E5E5.jpg
Alloy sump is huge to encompass the huge crank girdle
Fit perfect with the sump pan removed.
th_47C145AEC9DFBDA56BA54F53DD74B531.jpg th_873A3E0888FBFC9D09F2751D8D8CF24F.jpg
48
42 14.41kg & the girdle is made of alloy
th_E2512B0929AFB65CC485BE7344EE2EEE.jpg th_5F588F071B76F0056E97C29FE82513E1.jpg
37
th_A75E86CBEB057BABB375808B56930177.jpg th_FC887384E89C2FD9AA918428164A427E.jpg th_6B6E3A5011C5E62118E8C33C7F4F10D6.jpg
30
th_E23030D5EF19F2D879163A1610981F35.jpg th_99F56ED48F7D0B2460974A23188ADBC6.jpg th_6D6AC68D24345404C9EE0EF1948A3BDD.jpg th_DB8FA7765E2FA93B6667C13D4F52F240.jpg th_F53C4B0E963155900518BDCF8EC71F1A.jpg
20
th_DBF8080791561561EB42F93A6FE78205.jpg 1635 th_297E8AC1A192AE527875DFC5F8C1F625.jpg
19
th_54D6DDA6984E9FAA646DC5C037C669B9.jpg th_3288E5A4AB8588B3B1AB22E30AF4204A.jpg
11
4
th_E89EAF9218C8A7438F8B3BB4A2021E71.jpg th_E8898515978E33A872AE1E15FE9F5987.jpg th_52E7FD2311FB18796CCA2B995BC3FB55.jpg th_41382CF8004216FBB1B54C95DBA969D5.jpg
3
1648
1747
